Old 14th November 2009, 07:41 PM   #1
Antonyhu's Avatar
Question Using fireplace and chimney to mount IB subs?
First post here and it might seem a bit wierd but I have a problem finding a suitable location for my substage.
I wish to mount 2 IB subs in a fireplace and use the chimney to vent into the roof cavity.
The subs in question are the AE IB15's. I wish to mount them facing each other to minimise vibrations and seal them into the fireplace with a baffle.
Will the chimney be big enough to vent into the roof space without compressing the drivers? The chimney is about 3 feet wide and nearly 1 foot deep internally all the way to the roof cavity which is distance of about 7-8 feet.
Dont worry, the fireplace is no longer in use and the chimney through the roof has been removed when the new roof was put on. There are 2 other fireplaces in the house that are functional so its not a big deal(bought the house this way).
Ant
Old 14th November 2009, 08:24 PM   #2
Antonyhu's Avatar
Quick paint to help visualize. The red area will be open into the room. the blue area will be a flat baffle that seals the box and subs into the fireplace.
Ant
Old 14th November 2009, 08:55 PM   #3
davygrvy's Avatar
Dude, that's totally cool. Reminds me of this.
Think out of the box
Old 15th November 2009, 09:36 AM   #4
kipman725's Avatar
Send a message via MSN to kipman725
test the location out before building your open baffle by blocking the fireplace up and trying a normal sub in that location. Also check out: "Cult of the Infinitely Baffled"Hear The Bass, Not The Box The definitive online resource for Infinite Baffle subwoofer designEstablished 1999 - Home
Old 15th November 2009, 10:24 AM   #5
Cool idea but one small subjestion. I believe Lynn Olson subjested that when you mount 2 woffers like that you mount them with the magnets facing each other and
add a brace from magnet to magnet to cancel some unwanted vibration. I am not
positive it was Lynn Olson I read the article many years ago.
Old 15th November 2009, 05:40 PM   #6
soho54 is offline soho54  United States
This will not create an IB. You will end up with a sort of transmission line. Only the rear wave is thrown away, so it will have a very strange FR.
Old 16th November 2009, 07:09 PM   #7
Fuzzymuff's Avatar
Default Your answer
IB subwoofer FAQ page
scroll down to 19a
Wrap it in foil, and plug it in.
Old 16th November 2009, 09:18 PM   #8
Antonyhu's Avatar
Thanks for that info,
thats what I wanted to know. I guess its a no go for IB. I think I might just build a big ported box and hide it in the fireplace then. My main speakers are on either sides of the fireplace and my tv is on top of the mantel so its still a good place the sub.
Thanks everyone
Ant
Old 27th November 2009, 09:36 PM   #9
wingman is offline wingman  Denmark
Thanks everyone
Ant
It won't be a IB, but it will work as very large closed box.
"chimney sd" is 2787cm2 and AE IB15 830cm2 a piece total 1660cm2.
Do it, it will work fine!
uh, and I have an IB of my own
Wingman's IB
bass is music
Old 29th November 2009, 11:12 PM   #10
Collo is offline Collo  Australia
Collo's Avatar
Send a message via MSN to Collo
There will be soot...
Ports rule!
WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x Destroyer OS. Swap Meet 1 22nd December 2006 06:18 AM
DIY fireplace DSP_Geek The Lounge 5 28th February 2006 09:08 AM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
2 subs one box/2 subs 2 boxes vetkilr Subwoofers 5 22nd February 2006 09:27 PM
Where to Mount X-Over? r0lf- Multi-Way 6 7th August 2004 05:12 PM
Copyright ©1999-2013 diyAudio
