Just an idea I thought I would share with you
Commercial passive radiators does actually cost quite a lot Chassis could be simple plywood Or if proven to work, constructed directly into the sub Surround should be available as repair component The passive cone itself could be anything you can imagine From the most simple to advanced laminated materials The third one is a crazy idea from another thread Surround is a bicycle tube Airpressure should keep it in place Thats the cheapes one But may take some experimenting But thats the fun part, right Have fun
#2 |
Interesting idea, Tinitus. I wonder if you would need a spider and dummy coil assembly to keep everything moving in one axis?
Jim |
#3 |
Funny, i was just thinking of the same exact thing the other day. Two sets of surround with some offset between them should keep the 'cone' moving in one axis?
The bicycle tube idea looks real neat, but would be hilarious, as well as embarresing, if the sub literally blew up (both PRs cones bust out) during a loud explosion while watching a movie. |
#4 |
If ever you blow a driver, you can cut the magnet off it for a diy PR.
Here's one I "prepared" earlier... ![]() Some MDF with a bolt epoxied onto the coil former would accept the weights.
Ports rule! |
#5 | ||
Speakerholic
Tinitus, I made something like #1 many moons ago. Found it to be too much work when what Collo suggests is a good starting point. A plywood "basket", a piece of wood paneling, the sidewall of a small bicycle innertube, rubber cement and a whole lot of staples. Thanks for the memories.
![]() Quote:
Good to see these suggestions coming out again. Just the sort of thing that piqued my interest when I was but a wee tyke. All those years ago...
#6 |
I did this when I was ~17 years old. I had a 12" Radio Shack woofer in a very big box and built in a passive radiator in it. I started with a big hole in the box (around 20") added a flat ring of rubber (truck inner tube) about 3" wide to this. The diaphragm was cardboard, 2 pieces with the rubber sandwiched between. The outer edge of the rubber surround was held in place by a plywood ring screwed through it to the box. On first play, it was a bit sloppy so I added a thick rubber band from the centre of the diaphragm to the rear of the box (makeshift spider).
In the end, it didn't sound bad - way more bass than the 12 could do alone but lacking any of the knowledge I have today ( ) I could probably do better. Looked excessively cool though.
#7 |
I once used a passive radiator from CSS that didn't have a rear suspension of any sort, just a big, fairly stiff surround (what I assume Cal meant by "flapper plate", it was made in Germany, I can't remember the brand). The diaphragm was mdf (ish), and had a bolt to which one could attach washers as mass. I used it in a small, low tuned sub with the MCM 55-2421, and it sounded good! (I gave it to a friend). I don't know that it is super linear, nor how long it will last, but it was fun and price was right. I actually choose that design because most of the inexpensive PR's (at the time at least) didn't have nearly enough excursion and mass to work in the box. It sure beat trying to tune that little box to 30hz with a bunch of PVC elbows!
I think you can do as well. The biggest problem (I think) would be getting a suspension that will allow enough excursion, but is also reasonably linear in the range you will use it. Even that little 8" sub could really get the 10" plate flappin'. I honestly really like the inner tube idea. You might need to play with the gap a bit. Glue would allow it to be pretty wide. Paul Wild Burro Audio Labs - DIY Full Range Speakers |
#8 |
To be honest, I wouldnt expect it to be optimal at loud SPL
On the other hand, I wouldnt expect ANY design with passive radiator to be optimal at loud SPL, but what do I know about it, not much really I heard the first good one just recently, which got me interested When others asked about modifying a cheap broken woofer into a passive radiator, I thought why the hazzle It may never be any good But Im a bit late it seems, when MJL did it the age of 12 But he may be disappointed if he think he can do better today(grin, lost the smiley) I dont think that the spider and ordinary basket does any good in linearity Its only needed fore a conventional design And the ordinary design with a standard cone mounted with additional weight at the voice coil, I really dont think thats very good at all Seems to me like it would be much better to have the weight spread over the entire cone And I expect it to be more linear when in no need fore a spider Another thing, I suppose we have much better tools today, calculating the design The one I heard at båndseis place was just a rather cheap dayton, but careully adjusted with weight How is this ScSp 10" fore a passive radiator, at 150EUR And maybe you need two of them, pr sub Thats a lot of money Last edited by tinitus; 11th November 2009 at 01:21 AM. |
#9 |
I always liked the idea of a large passive with a wirewound pot across it's terminals, the pot alows you to tune the passive.
Terry
What we don't understand is called magic. |
#10 |
| Passive radiator | Chris8sirhC | Subwoofers | 4 | 5th August 2008 06:49 PM |
| Passive radiator | jamikl | Subwoofers | 1 | 3rd June 2006 10:23 AM |
| passive radiator ??? | Ahmad_tbp | Multi-Way | 20 | 29th March 2005 08:44 AM |
| Passive Radiator For ESS | qdoc | Multi-Way | 0 | 8th July 2004 06:06 AM |
| Page generated in 0.13223 seconds (80.21% PHP - 19.79% MySQL) with 11 queries |
