Passive radiator, build your own - Page 5 - diyAudio
Old 26th October 2011, 02:49 AM   #41
Einric is offline Einric  United States
Einric's Avatar
I don't suppose anything would stop a guy from buying a PE buyout woofer (12" $15) and cut the magnet off it.
That is half price from a 12" PR.
Old 26th October 2011, 03:44 AM   #42
That sounds like an lot of money to spend on a PR experiment. I just wait until I find a pair of speakers on the side of the road and mod the woofers out of them for passive radiators.
Peace,
Dave
Old 29th October 2011, 06:14 PM   #43
Ron E is offline Ron E  United States
Ron E's Avatar
Originally Posted by TerryO View Post
Ron,
I get the sense that you remember this from... (the Bass List?)
Dan certainly did the Math, although I checked his work and made any necessary corrections.
A copy of Adire's RDO paper is here:
http://stereointegrity.com/Files/RDOOperation.pdf
"The math behind RDO is fairly simple; the best explanation/set of equations we've seen comes from Ron
Ennega, and was posted at Brian Steele's DIYSubwoofer site:
First you need the original Rms:
Rms = 2 * pi * Fs * Mt / Qms
Next calculate:
Rms'=Bl^2 /(Re + R) where R is the shorting resistor
Rmt = Rms + Rms'
The new Qms is:
Qms' = 2 * pi * Fs * Mt / Rmt
Qes does not change:
Qts = 1/(1/Qes+1/Qms)"
To which I would make the correction that:
Qts = 1/(1/Qes+1/Qms')
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 30th October 2011, 08:24 AM   #44
TerryO is offline TerryO  United States
TerryO's Avatar
Next calculate:
Rmt = Rms + Rms'
The new Qms is:
Dan Wiggins did some of the preliminary math but, as been pointed out here, Ron Ennega did the really "deep" math (as was usual on the the old "Bass List"). I was being too hasty in replying and forgot to mention Ron's vital contribution.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 2nd November 2011, 02:55 PM   #45
DAMIC is offline DAMIC  Seychelles
Is there something else wrong if magnet stays intact, beside reduced volume?
Old 2nd November 2011, 08:58 PM   #46
djk is offline djk
djk's Avatar
I generally leave the magnet on.
I do cut off the voice-coil below the spider joint (remove the dust cap, pull the cone up, and cut the coil former with an exacto knife, yank the coil out with pliers).
Candidates for the Darwin Award should not read this author.
Old 2nd November 2011, 09:24 PM   #47
Collo is offline Collo  Australia
Collo's Avatar
Send a message via MSN to Collo
Usually you will need to add mass to tune the PR. Removal of the magnet gives you somewhere to put it.
Ports rule!
Old 2nd November 2011, 09:47 PM   #48
epa is offline epa  Netherlands
question: why not leave the magnet/vc on.then you could tune the pr with a (variable)resistor between the poles?
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 2nd November 2011, 11:42 PM   #49
djk is offline djk
djk's Avatar
"Removal of the magnet gives you somewhere to put it. "
Removal of the dust cap gives you a better place to put it, between the surround and the spider.
"question: why not leave the magnet/vc on.then you could tune the pr with a (variable)resistor between the poles? "
I would wonder about the excursion capacity. Cheap woofers will slam the coil-former against the back-plate, and you will probably be adding a bunch of mass too. The coil could also pop out of the gap in front and get hung up too, especially with some added mass.
Old 3rd November 2011, 02:33 AM   #50
Ron E's Avatar
That won't "tune" it. The resonant frequency will stay the same, it will just reduce output.
Passive radiator Chris8sirhC Subwoofers 4 5th August 2008 06:49 PM
Passive radiator jamikl Subwoofers 1 3rd June 2006 10:23 AM
passive radiator ??? Ahmad_tbp Multi-Way 20 29th March 2005 08:44 AM
Passive Radiator For ESS qdoc Multi-Way 0 8th July 2004 06:06 AM
Copyright 1999-2017 diyAudio
