Old 7th November 2009, 05:45 PM   #21
davygrvy's Avatar
I examined the cross-section view of the EL36C just to check some dimensions with hornresp. It looks like the compression ratio is whooping 0.81:1. This not a front loaded horn. It's all back loaded. The horn appears to be only a conversation piece to get the sensitivity numbers up at 100Hz.
Hornresp info that I estimate:
Ver=23.40
Ang=0.5 x Pi
Eg=2.83
Rg=0.00
Fta=6.38
S1=1182.00
S2=1436.60
Con=40.00
F12=0.00
S2=1436.60
S3=2304.00
Con=63.20
F23=0.00
S3=2304.00
S4=4276.30
Con=87.76
Sd=962.00
Vtc=41522.00
Atc=962.00
Com=Cerwin Vega EL-36C
Old 7th November 2009, 06:22 PM   #22
Originally Posted by juxta View Post
I think I should work with what I've got so I'll try to find something to utilise my 400w Qsc...
400 W is PLENTY to start with, especially considering you'd have to go all the way to 4000W of power (if your subs could take it) to gain 10 more dB through power alone. Jim ran all 4 of his off 1/2 a EP2500 if I recall correctly, and makes plenty of noise.
Old 8th November 2009, 02:37 AM   #23
juxta is offline juxta  Australia
Originally Posted by davygrvy View Post
What's the max SPL you're after? Normal rock levels of 107 average 25 feet out?
I was told by littlemike:
According to the manufacturer, your KP-362's make 102 dB with 1 Watt and are -4 dB @ 55 Hz. Looks like you want efficient subs that would reach an octave lower, so you'd want something that played a bit deeper than Jim's design. The KP-362 will each make 126 dB at full power, ideally you want the subs to produce a bit more than that. You may need multiple subs to get there (2 per main)
Some of the electronic/dubstep I've played with has content way down low (20 to 25 Hz.), so no matter what you do for a sub - it would be wise to run a strong (48 dB/oct) highpass filter to save your drivers and use the amp power where it matters.
After all this -
Answer #1 = From 30 Hz to 100 Hz.
Answer #2 = Greater than 100 dB 1W/1M
Old 8th November 2009, 02:40 AM   #24
Thanks mike,
How does he run 1/2 a EP2500?
Connection wise?
Old 8th November 2009, 02:41 AM   #25
So this is why they can use a 18".....
Old 8th November 2009, 10:36 AM   #26
davygrvy's Avatar
Or put another way... this is why an 18 in a horn is not an efficient horn. pressure = good.
Think out of the box
Old 8th November 2009, 10:32 PM   #27
jbell is offline jbell  United States
Thanks mike,
Connection wise?
I ran one ep2500 for subs (2 per channel for 4 ohm load) and another ep2500 for tops with tops in series/parallel for 5.3 ohm per channel.
Old 9th November 2009, 02:31 AM   #28
Thanks jbell
Old 9th November 2009, 06:19 AM   #29
Sorry - Knew you had EP's running it, could not remember if it was one or two
Old 9th November 2009, 06:22 AM   #30
Thanks mike,
Connection wise?
Well - I had to - I'd run the subs on one side series-parallel wired, and the tops wired series-parallel on the other side.
As long as the impedance is within the range the amp can handle, it will be fine.
How do you deal with "backside" bevel of driver cutouts? madisonears Multi-Way 6 30th August 2009 07:22 AM
12" "guitar" driver in Audio Speakers jwhit67 Multi-Way 4 11th February 2008 03:47 PM
looking for a small 2" or 3" driver with poor bass response space-cake Full Range 3 27th December 2007 02:16 AM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 01:09 AM
Page generated in 0.11619 seconds (80.49% PHP - 19.51% MySQL) with 11 queries
