#11 | |
What's the freq. response like? Do you get a clean 20 Hz indoors?
"Any fool can know. The point is to understand" - Albert Einstein |
#12 |
hi bjorno - how might you build a "modern" Karlson-style speaker using hornresp?
#13 |
Well my K15 with undersized 12" hole and oversized SigmaPro18" hiding behind seems
quite similar to what I see in this sub's photo. Mine worked much better after I had opened the hole to the full size. Mind you though, I was only choking the front side of the driver, not the whole front of the inverted horn mouth. |
#14 | |
Not quite. Your K15/18/12 had hardly any clearance between the baffle and the driver (more similar to the gawd awful ripole sub i built two weeks ago), whereas in this case, the opening is part of the horn terminus. In this case, if I remember the theory, the terminus openingcross sectional area = hornresp specified Sx (x = last segment), ... and the negative taper is necessary to achieve a lower freq. response.
"Any fool can know. The point is to understand" - Albert Einstein Last edited by zobsky; 2nd December 2009 at 09:35 PM. |
#15 |
Your ripole had completely different issues. I don't see any similarity.
Mine was choked in the focus of the cone, yours off to one side... The acoustic short circuit around K15 shelf might be of about the same as a ripole, but a huge difference how extra air gets swept up in tapped horn and K effect and added to the wavefront that radiates into the room. Last edited by kenpeter; 3rd December 2009 at 05:29 PM. |
#16 |
what I'd like to know is what easy mod might be done to the simple one-fold inverse or positive taper tapped horn/pipe to mitigate their typical suckout
7.4 cubic foot inverse tapered pipe with 15" Dayton 295070 speaker vs 7.7 cubic foot K15 with Audio Nirvana Super10 - one trace has the mouth panel removed giving an opening larger than Sd - tuning and cutoff are a bit higher - for an experiment a Karlson slot might be used. ![]() Input impedance with 295070 ![]() to keep a pipe looking like a Karlson, and give it a positive flare with somewhat higher cutoff in a given bulk perhaps "this"
| B&G NEO8 PLANAR TRANSDUCER crossed to two Dayton classic 8"(DC200-8) | nunayafb | Planars & Exotics | 28 | 13th April 2009 09:28 AM |
| Tapped Horn for 18" bass | angeloitacare | Subwoofers | 14 | 28th March 2009 08:37 AM |
| MCM 55-1170 or Dayton classic 6.5"(295-305) ? | percy | Multi-Way | 2 | 21st July 2007 01:27 AM |
| dayton 10" classic woofers for PA... | nerd of nerds | Multi-Way | 13 | 29th May 2006 03:24 AM |
| Page generated in 0.10078 seconds (72.26% PHP - 27.74% MySQL) with 11 queries |
