My first DIY Sub
My first DIY Sub
Old 4th November 2009, 06:36 AM   #1
rhapsodee is offline rhapsodee  Malaysia
Default My first DIY Sub
Hi Everyone!
This is my first effort at a DIY subwoofer. This sub was designed with the generous help and advise from the bass enthusiasts on this forum. Any comments and suggestions appreciated!
The driver - Rockford Fosgate RFR3115 subwoofer
The plan - Thanks to Bjorno
I chose to use 1" thick marine plywood instead of MDF to reduce the weight of the sub, due to its size. Needed about 1.5 sheets for the design.
Glueing the sides. I used a lot of bracing to reduce panel vibration from colouring the sound.
Despite my best efforts, this thing is crazy big.
I used two cross braces for the woofer magnet bracing. I have read that it helps to clean up the sound. Also works as additional bracing.
The wheels are on! Another view of the magnet bracing.
I used deans connector for for the wire between the amp and driver for easy disconnection.
All assembled!
I left the top open to fine tune the line stuffing.
I have yet to fasten the top, left it open for tuning and stuffing. What would be a good approach to stuffing this baby? Should i line the sides with foam, or fill the line with polyfill?
Old 4th November 2009, 06:57 AM   #2
Akita is offline Akita  Malaysia
Well, You can shake the building with this woofer
Old 5th November 2009, 09:04 PM   #3
Hey guys, would really appreciate suggestions on stuffing material and distribution, especially if you have built a similar TL layout previously.
Old 19th November 2009, 02:23 AM   #4
form109 is offline form109  United States
Wow....Nice!....this will definetly Crack your Foundation!
My first DIY SubHide this!Advertise here!
