I am currently using a Yamaha active subwoofer to subtly extend down the freq. response of my Richard Allan Minette II bookshelf speakers. Due to changes in the layout of my living room, I am having to reposition speakers and sub.
I would appreciate any advice regarding the characteristics of the cable needed to connect sub to amp (I am using speaker level connections due to the lack of any volume controlled line level output on Marantz PM44SE). Listening levels are generally pretty low and music is generally baroque/small ensemble classical. The cable needs to be as unobtrusive as possible as it will be visible through some of its 6 metres length. Please bear in mind the budget nature of the system when making suggestions!! Thanks. |
#2 |
It doesn't need to be anything special. Find something inexpensive of the right length and appearance and you'll be fine.
#3 |
Cool. Someone very nearby.
Like Brett said - you don't need anything particularly expensive. Most noise comming from cables will be filtered out by the subwoofer.
iPod Touch (playing LossLess) > 4th order LR crossover @80Hz > Amp-6b > Fostex FE126eN in folded ML-Voigt Pipes ------------------------------------------------------------> Samson Servo 240 > W6-1139SG Tapped Horns |
| active cable schematic | ackcheng | Parts | 17 | 15th April 2005 01:58 AM |
| USB Active Extension Cable | ElectroPower | Parts | 0 | 3rd February 2005 02:19 AM |
| subwoofer cable? | zachary | Subwoofers | 3 | 4th October 2004 08:13 PM |
| DIY active cable | Koy | Solid State | 37 | 17th April 2003 01:09 AM |
| Page generated in 0.06361 seconds (69.81% PHP - 30.19% MySQL) with 10 queries |
