Hey!
So, I just finished the Steve Bench phono pre with Salas' shunt regulator for the power supply and it's time to talk subwoofers. My current system includes some 300b monoblocks into either a pair of Fostex 206e backhorns (in the 208E-Sigma enclosure) or a set of Supravox 215 signature bicones run on open baffle, which is what we're here to discuss. I'm thinking I would run some Eminences (Alpha?) with the open baffle Supravoxes, but any guidance on this would help. They're in a pretty big room and I need a good degree of bass help to round out the sound. Any advice would be appreciated. Kofi |
#2 |
Do they have to be OB or are "box" sub designs OK?
Jim J. |
#3 |
Chambered downfiring woofers ,high sensibility ones ,which may be difficult to find , so SS amp with average 88 SPL woofers.
My question is if R U going to cross and amp them 'ctive ? |
#4 | |
I am open to all ideas. I have seen a pair of Alphas per channel and one Supravox on one OB before and I thought that had potential, but I am willing to consider anything.
Kofi |
#5 |
A pair of Alpha 15s are common here, but only on OB - you couldn't make a boxed sub with them.
Chris
iPod Touch (playing LossLess) > 4th order LR crossover @80Hz > Amp-6b > Fostex FE126eN in folded ML-Voigt Pipes ------------------------------------------------------------> Samson Servo 240 > W6-1139SG Tapped Horns |
#6 |
Might check here for inspiration: http://www.lampizator.eu/SPEAKERS/PR...0projects.html
#7 |
I use 18 inch 650WRMS Eminence Sigma Pro's in my big setup.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#8 |
#9 |
Anyone?
Also, any ideas on designs for active crossovers? Kofi |
#10 |
As far as active crossover goes I've got a reckhorn f-1. ~$50 from CSS. It's much nicer than what was in my plate amp. I like it a bunch.
Creative Sound - Product Details Emminence or big cheap Goldwoods in an H-frame is what I see mentioned for open subs, not that I've experimented with that setup... |
| Kofi Annan in: "Kofi's Living Room" | Kofi Annan | Full Range | 5 | 25th May 2008 06:19 PM |
| Kofi Annan in: "Kofi Makes a 300b DRD... and You Get to Help!" | Kofi Annan | Tubes / Valves | 135 | 15th October 2007 07:15 AM |
| Kofi Annan in: "300beee!" or "Kofi Gets a Toy" | Kofi Annan | Tubes / Valves | 125 | 25th August 2006 04:39 AM |
| Page generated in 0.13460 seconds (70.09% PHP - 29.91% MySQL) with 10 queries |
