ok so i went and bought a 12" woofer, I put it in my 12" subwoofer box and it doesnt fit tight, the sub seems slightly small, however i measured my sub and its exactly 12in. The sub that used to be in this box was 12" from manufacturer. i measured it, seems it is like 12" and a few milimeters, any ideas how I can make the hole abit smaller? a few milimeters will do.
#2 |
The method most people would use is get a piece of MDF, cut the right hole in that, then screw it over the too-big hole. Alternatively, a whole new panel could be used.
Chris
iPod Touch (playing LossLess) > 4th order LR crossover @80Hz > Amp-6b > Fostex FE126eN in folded ML-Voigt Pipes ------------------------------------------------------------> Samson Servo 240 > W6-1139SG Tapped Horns |
#3 | |
In order to make a hole in wood smaller, typically you need a board stretcher... It's also very useful when you cut that board twice, and it's still too short. ![]() However, if you just need a good tight seal to the box, a strip of this applied to the back of the driver, is just the ticket. MD Building Products 1/4 In. x 1/2 In. x 17 Ft. Gray High Density Foam Weatherstrip Tape - 02279 at The Home Depot In all seriousness (joking above aside) The easiest way to accomplish what you are looking to do (if it is actually necessary) is to cut a very thin strip of hardwood the width of the thickness of your driver baffle, and then polyurethane glue it in place. If you only need a couple millimeter, you may even look at using some solid wood veneer for this. |
#4 |
I agree with jbells first suggestion. If you're only looking to fill a few millimeters, weatherstripping or plumbing caulk or something squishy might be your best bet.
| Comment on PCB and how to make it smaller | Yoshy | Solid State | 10 | 18th November 2008 06:07 PM |
| importance of pin hole pressure equalization and how to make one safely | mazurek | Subwoofers | 33 | 15th December 2005 09:42 PM |
| Page generated in 0.08252 seconds (70.39% PHP - 29.61% MySQL) with 10 queries |
