What is the best cabinet for Peerless XLS 12 ?
My amp is a BASH 500. Thank you , Claude . |
#2 |
Here's one possibility:
Critical Q Sub-Woofer It requires a little bass boost, and I'm not familiar with the BASH features. - Pat
www.buyoutdickvitale.com: Pledge money to enable ESPN to get Dickie V off the air |
#3 |
thank you very much ! I will make this Q-SUB
#4 |
my new sub !
#5 |
other picture
#6 |
That was quick.
iPod Touch (playing LossLess) > 4th order LR crossover @80Hz > Amp-6b > Fostex FE126eN in folded ML-Voigt Pipes ------------------------------------------------------------> Samson Servo 240 > W6-1139SG Tapped Horns |
#7 |
#8 |
How does this sub sound? I have a pair of these speakers, with the same amp (x 2). I was looking to build this unit(s) as well (two of them)... Would you make any changes to improve?
Mike |
#9 |
#10 |
I was playing around in hornresp on this driver a couple days ago trying to find a combo that gets me 20Hz without being too long. The path is a bit long with this driver at around 5 meters, but I'll post it here just for fun.
Although the voltage is limited to 28V due to displacement @ 25Hz (not sure if the T/S params are for series or parallel coils), the efficiency of the cab will get you 20Hz at 125dB when placed in a corner. Not too shabby, 'cept for the long path which makes for a HUGE box.
| Peerless XLS 12" in Shadow Cabinet... | speakrsrfun | Subwoofers | 0 | 9th June 2008 04:00 AM |
| Cabinet design | jwhit67 | Multi-Way | 4 | 14th February 2008 04:46 PM |
| Anyone looking for Peerless HDS 2-way design? | Jay_WJ | Multi-Way | 6 | 7th October 2007 05:31 AM |
| how's this for cabinet design? | legendaryfrog | Full Range | 13 | 20th November 2006 11:23 PM |
| Page generated in 0.10932 seconds (73.81% PHP - 26.19% MySQL) with 11 queries |
