#11 |
(At the risk of sounding ridiculous)
The greatest power is transferred when the impedance to the force being applied is equal to the force itself. To put it another way, imagine yourself punching air. Yeah, how does it feel? Now trying punching underwater? Tougher, huh? Need more power? If there were a medium which could perfectly "accept" the power in your punch, 100% of your energy would be transferred to that medium. When punching air, you'd be just burning up some muscle (or fat). You can take this and pretty much apply it to loudspeakers. Horns create that extra pressure to allow a greater transfer of (sound) energy from the diaphragm to the air. Otherwise, the diaphragm is just "punching" air. And no, no bending of physics laws is happening here. Not yet, anyway! ![]() Enjoy! |
#12 |
This thread has helped a lot - Thanks All.
Chris
iPod Touch (playing LossLess) > 4th order LR crossover @80Hz > Amp-6b > Fostex FE126eN in folded ML-Voigt Pipes ------------------------------------------------------------> Samson Servo 240 > W6-1139SG Tapped Horns |
#13 | |
Can you explain what represents the matching network's lumped C and L equivalants in the horn? Thanks. |
#14 |
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
Hi
Well how that ties in requires a more complicated answer. For an efficient horn, the length has to be a half wavelength at the low corner. This is because the driver has to be at the velocity maximum and the exit has to be at the other velocity maximum. In that case, the horn is like a T network because the center point impedance is set to be the geometric center of the input and output. For a horn, Area equates to the impedance /resistance etc and in an exponential horn, one sees the area at the half way point is also the geometric mean. In practice we are forced by the size to make the horn a quarter wl at the low cutoff instead and this greatly reduces the impedance span the system can adapt to. One finds that the driver parameters needed to be efficient above the low corner are much different than those you need when the driver is at the velocity minimum. AS a result, the quarter wave horn, when you examine its impedance, you see that it isn’t optimally efficient until it’s a half wave long. Like the antenna, it is the ratio of the reactive to resistive parts which govern the standing wave. With the horn, one is concerned with the resistances at both ends as well if these are dominant, the appearance of a resonant system is lost. In the antenna world, there is a useful analogue to a horn at it’s low cutoff, the Biconical antenna. At the low corner, it’s entire length is in use but as the frequency climbs, the amount of the antenna “in use” is less and less. Here, the geometry is “correct” or close, for any frequency within it’s operating band. An acoustic horn propagates pressure axially however its active region retreats down the horn as you rise above the low corner. In the acoustic horn, the horn segment which is past the impedance matching region is not exactly gone though, it continues to define the horns radiation pattern up to some still higher frequency. Hope this helps, Tom Danley
Bring back mst3k and futurama |
#15 |
I would have thought, in an acoustic horn, impedance transformation took place at one quarter wl. I keep associating it with the 1/4 wave transmission line stub, in the rf realm, goes from max voltage, min current to min voltage, max current at 1/4 wl down the line. A shorted line appears Hi Z at 1/4 wl away from the short. Getting old ain't helping me getting a grasp on the horn analogy.
I've built Hi Q RF duplexer filters using 1/4w stubs and achieved a massive notch with a recovery (passband) above or below by adding shunt C or L. But, dang this broadband acoustic spew has me baffled. Thanks Tom. |
#16 |
Hi
Ah, acoustic spew, yes. Think of the horn in terms of the passive 3 element T network. The center impedance etc. The quarter wave resonator is similar but it is the > half wave horn that is “efficient”. To make a quarter wave horn efficient, requires a different set of driver parameters, one with a much stronger motor and greater mass and not so suitable above ¼ wl. In other words like with an antenna a source with an impedance capable of driving at the current maximum and not voltage maximum. With antenna’s the Voltage maximum is an impedance so high it is normally impractical to drive from anywhere near that end. The air around you presents much more of a load than the RF radiation resistance of free space if that helps. In acoustics the concept of an equivalent circuit is also useful and valid although less used, if you used to antenna’s, I would say try that direction. Look for Marshal Leach and others who have published on the Pspice equivalent circuits for drivers and horns. Examine the conical antenna for the broad band nature, it is a quarter wave antenna at it’s low cutoff BUT is capable of operating above that because it’s aperture changes with frequency. Antenna’s by Krause has a good description. Where the antenna works radially, the horn is axial, throat to mouth. Lastly, this stuff is frustrating, hard to picture and most of all, it is not an age thing, it’s just not simple or obvious or described in terms that make sense immediately. Understand too there are big differences between EM and audio it’s just that the wave nature makes for some useful analogies. 73's Tom
#17 |
Oh the speaker equivalent of the coaxial colinear array would be so easy if it wasn't for those so many octaves...
Thanks Tom, I enjoy the challenge. 73's Dan N5MRG |
#18 |
There's one of the problems in understanding audio - a "wideband" antenna might do a tenth of an octave whereas audio we're looking at many octaves.
My brain works best in considering a horn not as a T circuit, (which relies on discrete discontinuties and a single frequency) but as a transmission line whose impedence changes along it's length. The nasty bits are getting the impedence change well behaved over the desired range while also matching the mouth & exit impedence and getting frequency independent directionality (dispersion) |
#19 |
Hi
A real issue here is that the Q of a simple antenna or resonator governs it’s usable bandwidth. In airborne sound, the Q is partly set by he area and frequency and the highest Q one can get in a horn is far lower than an antenna. Like any passive element matching network, the bandwidth is inversely related to the impedance span one is trying to bridge. Search out “antenna’s” by Krause which treats several wide band antenna designs like the biconical and others in chapter one and especially in chapter 8. Antennas j d kraus 2rd edition solution - Rapidshare Search These are a “variable” antenna, not like a log periodic which has discrete nodes, and being omni directional, have no forward gain, just a broad band behavior. Some can be very wide band too; HF Broad Band Conical Monopole Antenna Keep in mind for an acoustic horn, the efficient range of operation is more like an octave or two, in order to make one horn be efficient over a larger bandwidth, takes different drivers suited to the frequency range in question. We make such a horn, perhaps the explanation for it will help, go about half way down; http://www.danleysoundlabs.com/pdf/danley_tapped.pdf Again, keep in mind that the horn is an axial thing while the conical antenna radiates radially. Lastly, it may be that you will have better luck dealing with the equivalent circuit of a horn and driver, here are a few places to start. Analogous Circuits for Acoustic Horns W. Marshall Leach, Jr. SpringerLink - Book Chapter http://www.acoustics.hut.fi/teaching...ogies_2009.pdf Hope that helps. Tom Danley
#20 |
OK, I think I just found some unobtainium. There's no way could I explain it though.
There's a complex juggling act going on in Tom's head. Thank you Sir. |
| Two drivers loading the same horn. | Tyimo | Full Range | 23 | 20th February 2009 04:19 PM |
| Horn loading a built sub | qguy | Subwoofers | 3 | 25th October 2008 11:32 AM |
| Help with horn loading | Web Wolf | Multi-Way | 3 | 25th October 2006 07:38 PM |
| horn-loading: 100% efficiency ?! | e-side | Multi-Way | 54 | 1st August 2006 03:42 PM |
| Page generated in 0.20342 seconds (76.04% PHP - 23.96% MySQL) with 10 queries |
