#42 | |
Feedback from the speaker is the last great frontier - well, a great frontier, if not the last. Without feedback, you can't improve. And there's no feedback from the speakers. And today's best speakers perform as well as the best amps of 1950, on a good day. As far as protecting speakers from being over-driven, gotta be a lot simpler ways than with radar. Last edited by bentoronto; 11th January 2010 at 05:19 PM. |
#44 | |
http://en.wikipedia.org/wiki/Ringing_(signal) The paramount question though, as far as I'm concerned, is how feedback (from the driver) could possibly help reduce ringing? That's a phenomenon that occurs simply by the very nature of the driver using an inductor. You really can't stop the tendency of an inductor to ring, you can only deal with it in some way. The "standard" solution seems to be a DC-coupled amplifier, sporting an extremely high damping factor, which can tightly control the amount of current within the resonant circuit comprised by the driver - the Crown K2 is a good example of a DC-coupled amp, with a damping factor of 7000 at the low end, IIRC. Can someone point me to a thesis statement on this feedback stuff? What might one hope to do with the feedback data - maybe throw more capacitance into the network to counteract the ring? What's the net benefit? Am I off my rocker or what? |
#45 | |
Never the less, embracing the accepted, if dubious, rhetoric you find in anonymous testosterone forums in the audio (and, even worse, the motorcycle) worlds... Look here (esp. at the download paper URL at the very bottom): Tech This is about capacitive motional feedback that I happen not to think highly of. But it illustrates pretty well about the topic and shows the measurements on frequency response and distortion. Footnote: even with remote sensing to eliminate most of the speaker wire resistance (as in the Kenwood Sigma Drive feedback), you can never get help from DF over maybe 15 because the speaker voice coil DC resistance will always be in the circuit, I truly believe. Remarkable of davygrvy not to believe you can control a loudspeaker by controlling the input to it. Remarkable, I truly believe. Last edited by bentoronto; 11th January 2010 at 08:51 PM. |
#47 | |
Anyways.. I would never consider a closed loop feedback system for the control of distortion using X-band radar for a number of reasons. Feedback systems can be quite fragile. The Velodyne is a fine example of such fragility. I do like it for preventing distortion in front-loaded folded horn subs caused by only over-excursion in a PA setup where loudness is paramount because you have to run it all close to its point of death or you aren't getting the most from it.
#48 | |
A feedback system will just drive it harder into the damage zone. If you went the other way to reduce level rather than increase, you've gone in the correct direction for the distortion caused by over-excursion. I am controlling the input. Ben, you have really got to get out more and make stuff.
#49 |
Mix guides monitors meyer sound x-10 Field Test-Mix reviews the meyer sound x-10 linear control room monitor in mix guides monitors meyer's take on servo (microphone in the loop)
| Radar Detectors | DavidWardlaw | Everything Else | 1 | 22nd June 2007 03:46 AM |
| WTB Siemens .22uF MKV, radar/transmitting chokes | Tweeker | Swap Meet | 0 | 15th December 2005 12:06 AM |
| radio , tv station and radar stations still use the best single end class a amplifier | single end | Tubes / Valves | 16 | 30th August 2005 07:45 PM |
| driver displacement | joelives | Multi-Way | 2 | 11th June 2003 06:02 PM |
| Dhaen sneaks under the radar... 1k posts! | pinkmouse | Everything Else | 3 | 11th February 2003 08:40 PM |
| Page generated in 0.13536 seconds (79.00% PHP - 21.00% MySQL) with 11 queries |
