i use a jbl ES250P subwoofer (covered the port bass sounds tighter to me) usualy the volume from 1 to 10 is at 3 , my question is adding a 2nd subwoofer will improve the sound or make it darker/muddy ?
i was thinking of buying Kef C4 link to jbl sub : JBL Home Audio link to Kef Sub : C SERIES |
#2 |
You will find a paper at
http://www.harman.com/wp/pdf/multsubs.pdf about using multiple subwoofers. Adding subs improves the performance. I might add that the subs all receive the same mono-sub signal. But then if one used stereo subs , meaning a sub that recieves only the signal from that channel , I wonder if this is still applicable. Within limits I don't see why not ! Cheers.
AM |
#3 |
I agree with multiple subs approach. Currently, have 3 subs x-overed at
100Hz 24dB/octave. Bass is now much better than eralier with 1 or 2 subs. |
#4 |
x3 on the multiple subs
Jim J. |
#5 |
Also agree on multi subs.
However as this is a DIY forum, perhaps it would be better to ask which subs to build, rather than buy. If you can do the woodwork, you stand to reap a larger performance benefit with DIY in many cases and can customise the size, shape and appearance to suit your needs. Lots of build examples at HTGuide, AVSForum and Home Theatre Shack, all in the DIY speaker sections. HTS also has Illka's extensive SW test reports |
#6 |
2 or more subs is a necessity to help kill room modes. The harman paper (info also in a JBL brochure) is a condensed version of what is in Floyd Toole's book where he gives a very understandable explanation of what is possible).
There is a thread here http://www.diyaudio.com/forums/multi...-approach.html that discusses a similar approach. To take full advantage of this it would be nice to have a JBL synthesis-like system that controls levels, delay & some EQ for each woof separately (and do the calculations that determine that) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Just a quick thought on this,
Are you considering the spl matching of the two subs? In simple terms two identical drivers (double the cone area) will give a 3dB lift interms of acoustic output. If positioning is the root cause of the question then a great rule of thumb we used in the testing room was to place the sub in the listening position and move around the room listening for any room nodes until you found the best sound to your liking, then place the sub there and enjoy. OFC the best place ends up being the coffee table and your partner tells you you can't put in there cos the kids will trip over the cabling... also you can take advantage of the 2dB lift per surface (6dB in a corner) if you are wanting more output in general. Nice discussion btw Cheers Richard |
| Which Subwoofers get really low? | Dwn2rth | Car Audio | 12 | 25th April 2007 01:58 PM |
| DVC subwoofers | punkrokr1701 | Subwoofers | 2 | 24th December 2006 06:12 AM |
| New subwoofers | postman | Subwoofers | 30 | 14th December 2005 03:33 AM |
| Car Subwoofers? | maxdeaf | Subwoofers | 9 | 17th September 2003 11:48 PM |
| Page generated in 0.09854 seconds (76.94% PHP - 23.06% MySQL) with 10 queries |
