Built box too big, how to control excursion?
Old 11th October 2009, 05:43 AM   #1
Jameson Styles is offline Jameson Styles  United States
Default Built box too big, how to control excursion?
In my early days of audiophilia, I bought a 10" driver at my local surplus store for $25. No specs on it, AT ALL, not even a real rating on impedence. However, it has amazing excursion, a 2" or so voice coil, and a big honkin 45oz or so vented magnet, and a roughbacked poly-coated cone. When I knew nothing of speakers, I was SOLD.
However, I have now learned the ways of thiele/small. I know that high excursion drivers need big boxes. So I tore this driver out of the too-small box I built for it before and built a new, bigger box for it. About 1.5 cu ft.
At first I was amazed by the performance. It was smooth, deep, and the box rumbled just enough to tame any response peaks. It was just a lovely little subwoofer, powered by a 60w plate amp. However, on higher volumes, bass drums make the woofer go beyond xmax and clip, making that kinda "poof" sound.
So I wonder, what can I do? I think I built me box too big. I've already insulated three internal sides with fiberglass, would insulating the other two help to dampen out the overly low-lows that make it overdrive, or do I need to stuff it with pieces of 2x4 to reduce internal volume? I'm open to any suggestions.
Old 11th October 2009, 05:54 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
More damping will make the box seem bigger.
Try putting some bricks, chunks of wood, full paint cans, whatever into the box to see what happens....
I suspect your amp may be clipping thou.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Built box too big, how to control excursion?Hide this!Advertise here!
Anyone built a tube-based (6BE6 or 6HS8) volume control? GordonW Tubes / Valves 11 12th August 2013 06:33 PM
How much excursion is too much? scott_jcp Subwoofers 11 13th October 2009 05:56 PM
SPL and excursion 454Casull Multi-Way 10 20th April 2009 12:06 AM
OB vs BR: driver excursion bvan Full Range 5 13th January 2009 07:20 PM
