Old 5th October 2009, 08:50 PM   #1
lejaybo is offline lejaybo  United Kingdom
Default Car subwoofer
helllo peoples
i want to add some bass to a simple car audio system
the idea is to use a pair of 8inch drivers
one will be in a small enclusure for punch and the other in a ported design to give a little low end
does this sound like a good idea?
Old 5th October 2009, 11:49 PM   #2
No.
Old 6th October 2009, 02:51 AM   #3
Iain McNeill's Avatar
I don't think the superposition theorem works for Qts
You'll end up with the worst of all possible worlds - smeared bass.
I'd put them both in the same box, sealed, as big as you can make it fit. Drive them from a beefy stereo amp and tie the amp inputs together. Feed it from a subwoofer output.
Old 6th October 2009, 09:42 AM   #4
cheers guys
whats the best way to get decent punch in the bass aswell as low end?
Old 6th October 2009, 12:06 PM   #5
if you have some room, go hornloaded. i have an autotuba with just one tangband 8 inch does it quite well.
just one drawback, it's a big box.
Old 6th October 2009, 07:24 PM   #6
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Originally Posted by lejaybo View Post
cheers guys
I think the "punch" you're talking about may be found in the midbass, moreso than the subbass.
Good sound deadening, sealing up door panels and having enough power on the midbasses are all part of that. I've heard 6.5"s that kick you in the chest with midbass, although there's more install work than simply dropping them in stock locations.
Jim J.
Old 7th October 2009, 11:35 AM   #7
fresh
anyone used tangband's in a car system?
Old 7th October 2009, 04:00 PM   #8
Glowbug's Avatar
Yes, Tang Band makes some good stuff
Jim J.
Old 15th October 2009, 03:22 AM   #9
BP1Fanatic's Avatar
Parts Express DIY Project
subwoofer project, which subwoofer? Davlaf Subwoofers 12 9th November 2006 04:59 AM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 11:31 AM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 04:19 PM
I need help with subwoofer deisign: HUGE inexpensive subwoofer hottyson Subwoofers 16 4th May 2004 04:51 AM
My DIY Subwoofer Brett D. Subwoofers 21 12th February 2004 08:28 AM
Page generated in 0.09381 seconds (76.06% PHP - 23.94% MySQL) with 10 queries
