Old 24th September 2009, 06:40 AM   #1
defwing is offline defwing  New Zealand
Default 40-120Hz Tapped horn?
Quick version : What do you think is the best solution to fill the area between 40-120Hz? I was considering two tapped horns(stereo), with a 8" driver or two 6".
Long Version : Currently considering Dayton Reference series in 8", winISD models a nice flat quasi-butterworth ported box. I cannot get flat response in a tapped horn yet. Also looking at a few peerless or hivi drivers.
The few rules of thumb for tapped horns I have read consist of low QES and fs 1.5x the tune. To get a 8" driver suitable for tapped horn in this range would seem like a PA driver, probably no good quality wise?
I am mostly interested in sound quality although I am seem obsessed with a flat response when designing speakers, is this ideal?
Currently the system has
12" Tapped Horn, quarter length is 20Hz. Have set crossover to 50Hz by ear. Higher frequencies sound terrible through it, hence the need for this. The system does feel empty in this region as a result.
2x Vifa midbass 6.5", .707 sealed. WinISD says -3dB is 70Hz, -1 is 90Hz. As far as 6.5" go, these have little low end.
Old 24th September 2009, 04:30 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by defwing View Post
...Quick version : What do you think is the best solution to fill the area between 40-120Hz? I was considering two tapped horns(stereo), with a 8" driver or two 6"...
Hi, defwing,
See my suggestion using dual Dayton ST210-8 in a T-TQWT.
Note the phase response as well as the needed low group-delay, a requirement for quality (SQ) integration to the other main top speakers.
b
Old 27th September 2009, 03:39 PM   #3
otto88's Avatar
Originally Posted by bjorno View Post
Hi, defwing,
b
a very good point:
What parameters did you adjust to improve phase response and group-delay?
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 10:22 AM
Help with a tapped horn. mike james 533 Subwoofers 32 11th November 2009 02:34 AM
Tapped Horn behavior screamersusa Subwoofers 32 21st October 2008 03:31 AM
Page generated in 0.08626 seconds (70.33% PHP - 29.67% MySQL) with 11 queries
