You may want to consider the TC sounds sample drivers here?
http://home.comcast.net/~jhidley/
Pretty high excursion and looks well built.
Shiva-X @ DIY Cable
http://www.diycable.com/main/product_info.php?cPath=24_93_150&products_id=653
USD 149 each. They might be available from www.streamingaudio.se if you live in Europe.
Code:
SPECIFICATIONS
Fs: 19.6 Hz
Le: 0.90mH
Re: 3.6 Ohms (Voice Coils wired in parallel)
Qms: 2.60
Qes: .46
Qts: 0.39
Mms: 140g
Cms: 0.47 mm/N
Vas: 169L
Sd: 506 cm^2
Vd: 2.65L
BL: 11.66
X-max: 27mm (one-way)
Pmax: 600W
SPL: 86.3 db/1W/1M, 89.1 dB @ 2.83Vrms
Maybe the Shiva-X?
USD 149 each, www.streamingaudio.se if you're in Europe.
Code:
SPECIFICATIONS
Fs: 19.6 Hz
Le: 0.90mH
Qms: 2.60
Qes: .46
Qts: 0.39
Mms: 140g
Cms: 0.47 mm/N
Vas: 169L
Sd: 506 cm^2
Vd: 2.65L
BL: 11.66
X-max: 27mm
Pmax: 600W
