My father is a cabinet maker and has access to all kinds of tools and material so I thought he could make me a good subwoofer enclosure. However, we don't know much about audio equipment.
Are there good drawings for a subwoofer designed around cheap parts? Here's amp and driver I was thinking of getting
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-204
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-805
I browsed this forum back to 50-60 pages and did some searching but the schematics I found were either for multiple drivers or more expensive equipment.
Also, he could make a pretty complicated enclosure but we just need good schematic with all the numbers. But maybe I am just better off buying a complete subwoofer like Bic F12 or something like that for this budget ($150-200)?
if you download WINISD pro (free & easy to use), plug in the parameters of your driver,
you can find the correct cabinet size for your chosen driver:
http://www.linearteam.dk/default.aspx?pageid=winisdpro
For that budget, going DIY is definitely a better value
No real need to get fancy unless you wanted to, sealed enclosures can be really easy to build, and work great.
