building my 1st ported box,kicker L7
Old 1st October 2009, 02:29 PM   #21
scampo77 is offline scampo77  Canada
Send a message via Yahoo to scampo77
well the reason i was asking if the port "takes a breath", or if i can aim the port at the ceiling is because i am still tryiing to understand what the point of a port is (i am currently reading the article). for the sake of argument can i put the port outside of the car? if it is just taking in air to be compressed then this wouldnt be a problem. but if pressure or noise is coming out of the port then it would make sense to "aim" the port in the same direction as the speaker.
i am reading on BCAE1 as much as possible to try to learn about this but is there a link that explains all of the theile parameters in terms that can be understood by someone new to this?
i have decided to build 2 new boxes that are the dimensions recomended,6.2 cubic feet.
also can someone explain to me what is the difference between a hertz and a frequency? why am i tuning it to 30-40 hertz and what does that mean? at first i thought 30 hertz was a low note and generally speaking the lowest you will listen to most of the time? but now i am thinking that a frequency is the low note and now i dont know what a hertz is.
Old 1st October 2009, 04:31 PM   #22
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Hertz is the unit of frequency, also known as cycles per second.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 1st January 2010, 06:49 PM   #23
i am still working on these boxes and trying to get them to work even tho it is temporary. i have boxes that are built to inside dims of 2.25 cubic feet. i put the port in the box that kicker recomended and this resulted in the speaker bottoming out with almost no effort at all. i have the speaker out and i am willing to put a different size port in the box but i dont know what size to make the port. can anyone help me?
yes i know this box is too small and yes i understand that th port size wont give me 100% efficiancy but this is just temporary for now. i put new voice coils in these subs and i want to see if they are going to fly apart before i invest more time and money into larger boxes. i would just like to get a couple of hours of use on them in the boxes i have already built
Old 1st January 2010, 08:12 PM   #24
CKeeler is offline CKeeler  United States
download WinISD Pro off the net. it's free, and it will calculate your port sizes for you, just enter in the data and let it do it's thing.
Old 1st January 2010, 10:53 PM   #25
im still working on tryiing to understand winisd i have printed out the help tutorial and im on page 3 of 80. i was hoping if someone is good with this program they would mind helping me out
Old 2nd January 2010, 12:01 PM   #26
chris661 is offline chris661  United Kingdom
chris661's Avatar
A quick look at this bit may help you
LDSG Appendix A - Enclosures
Chris
My work: www.grimshawaudio.com
Old 2nd January 2010, 05:41 PM   #27
Cokewithlime is offline Cokewithlime  Canada
I'd be happy to help of you run into issues you don't understand
Old 2nd January 2010, 07:26 PM   #28
jwmbro is offline jwmbro  United States
jwmbro's Avatar
If you don't feel like reading 80 pages right away, this tutorial gave me a good grasp of the most basic usage within a few minutes.
Old 2nd January 2010, 07:31 PM   #29
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
it is for a car, well actually a work truck. I just watch a lot of movies in it. Is there another calculator that I can use that would give me something closer to the port volume that you are talking about. I'm using the calculator on bcae1.com.
Is my port volume off because my speaker box is larger than recomended, because I can make it a little smaller if that is the cause of my problems. When I turn it up too loud I get a violent crack noise from the speaker which I never got before from a sealed box.
Can I stick with my square port, it just that much easier to work with and change if needed, or do you suggest i switch and start using a round port? I was thinking of doing a square port at 3.5x3.5 id. how can I calculate the dimension of the port. I don't want to just guess at the dimensions.
Is it possible to tune the port to be able to listen to bass heavy music and still listen to movies and have them sound decent?
A work truck with a dvd player in it, GOD DAMMM! wish i could land my self a job that i can slack off in listen to rap crap boom around town with a company logo on it and watch dvd's soon you will be telling us that you text and talk on the phone too..!
building my 1st ported box,kicker L7Hide this!Advertise here!
Kicker L5 in a 1.75 box skooter Car Audio 4 16th October 2008 02:54 AM
Help With a Ported Box For Kicker Comp C12 kinser Subwoofers 1 2nd March 2007 12:53 AM
what is Ql ? ported box building questin jaygeorge1979 Multi-Way 7 13th January 2006 01:32 AM
Woofer Towers, front-ported or rear-ported? Goldenboy Multi-Way 6 15th June 2004 07:44 PM
building a slot ported enclosure bassman80hz Multi-Way 3 26th February 2003 07:59 AM
