Small sealed subwoofer
Old 14th September 2009, 04:05 PM   #1
Francesco is offline Francesco  Italy
Default Small sealed subwoofer
Hi all
I'm thinking about a DIY subwoofer, partly because I want to improve my current one (indianaline hc810: vented 10" 150w 27180 Hz) and partly because I'd simply like to build one.
I'd like a small and powerful sealed unit with external amplificator. The amp will 90% be this: behringer a500 which gives 500w 8ohm in bridged mode.
The box shouldn't be bigger than 50x50x50cm (50cm is little less than 20 inch).
So, first question: which 8 ohm driver would you consider?
Thankyou all for your help!
Francesco
Old 15th September 2009, 01:38 AM   #2
GM is offline GM  United States
GM's Avatar
Greets!
Well, the simple answer is a <27 Hz Fs 8 ohm 15" woofer with a ~0.4 Qts and ~3 ft^3 Vas with at least a ~500 W Pe and enough Xmax to handle it. That, or some mix of Fs, Vas, Qts to work well in such a small cab. One example is the AE AV15-X: http://aespeakers.com/shop/catalog/p...379b77321564b7
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Small sealed subwooferHide this!Advertise here!
servo sub for small sealed box? autopi Subwoofers 3 12th April 2008 03:49 PM
small sealed 8" oogared Car Audio 8 11th July 2006 07:39 PM
fx 120 in a small sealed cabinet audiothings Full Range 1 24th September 2005 12:03 PM
Small sealed enclosure Ddeele Subwoofers 15 20th January 2005 08:50 AM
how small of a sealed box could i get away with ? zuki Multi-Way 6 25th August 2004 08:12 AM
Copyright ©1999-2017 diyAudio
