#41 |
The AV series from AE are available with dual voice coils. That would let you use 2 amp channels for each driver to help overcome the 90W limitation. Or, for sub use at very low frequencies, you could just buy a cheap pro amp with plenty of power. Maybe a Behringer EP2500? I think power counts more than 'audiophile goodness' at sub frequencies and you'd have a hard time telling the difference between 2 amps with equal power.
Dennis H |
#42 | |
Here John measured both AV15H and AV15X : http://www.aespeakers.com/phpbb2/vie...3&t=1831#p8245 This is close mic technique, but at least it may help you a bit. As you can see, they have a resonance at 1 kHz and 2 kHz, but besides that they are real smooth. AV12H and AV12X measurements are not available yet.
DIYaudio for President ! |
#44 | |
Did you model the AV15H?? It should meet your needs....with a little bigger sealed box? Oh, 90W isnt much for any subwoofer....and the 100dB sensitivity ones you really should be looking at (Eminence, Faital Pro, JBL, etc) do not really go down to 30Hz in a sealed cabinet either. I think you need more power fo any subwoofer unless you never watch movies? btw, the TD series isnt really designed for subwoofer usage. They are pro audio main speaker woofers that run up past 1KHz very well and that is where their $$$/performance blows others away. Last edited by doug20; 22nd September 2009 at 08:45 PM. |
| WTB: Acoustic Elegance 15M | Ang | Swap Meet | 5 | 10th October 2009 01:22 AM |
| Acoustic Elegance TD12 - which version? | Defo | Multi-Way | 18 | 29th April 2009 05:56 PM |
| Many deals currently at Acoustic Elegance (former Stryke Audio) | simon5 | Subwoofers | 14 | 9th December 2007 04:23 AM |
| FYI : Acoustic Elegance (AKA Stryke) reopened and IB15 are available again... | simon5 | Subwoofers | 1 | 29th August 2007 03:16 AM |
| Acoustic Elegance/Lambda? | Sheldon | Subwoofers | 33 | 5th November 2005 04:11 PM |
| Page generated in 0.06955 seconds (83.64% PHP - 16.36% MySQL) with 11 queries |
