Hey all,
Been a while since I read and posted on here, My question / Situation: I live in a place now, for about the last year and I hardly play music or use any real subbage cause im just not aloud too, My sub is nearly 3 years old and in its first 2 years off life it was played hard! constantly but within its limts. My question is will not using my subwoofer as much for this length of time (1 year) cause a some sag in the suspension? ...my sub is front firing and the subwoofers are alpine 12" type R's If you need a pic just search "Dominator" I just dont want my sub to have any problems for a long time, it hasn't now just checking Like might I have to rotate them around fully for the same amount of time? or isn't it an issue with front firing? Thanks Cya |
#2 |
Sagging is always a problem (over time).
My 15" are also front firing, so I turn then 180 degrees once a year. I have earlier turned some of my older big drivers 45 degrees every three month. I'm not sure which method is best............
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 | |
The suspensions are very light to keep the mass down. If you really feel you need to change them then I would go for a 180 degree change once per year.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#4 |
I wouldn't worry about it.
Jim J. |
| FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) | theAnonymous1 | Swap Meet | 0 | 24th April 2007 12:09 AM |
| Chassis worries | NINfan | Chip Amps | 1 | 29th September 2005 05:41 AM |
| PSU worries... | yacuza | Tubes / Valves | 3 | 15th November 2004 02:49 AM |
| mtm versus tm driver recommendations on project with $500 driver and xo part limit | gsattler | Multi-Way | 4 | 20th May 2002 05:54 PM |
