Old 20th August 2009, 11:47 PM   #1
Default Sub design recommendation needed
I've a pair of line arrays that don't extend below 120Hz. Maybe with corner placement, i can maybe get a 100Hz, but nothing much below that. I'm not into bass heavy music, and am looking for something that will allow me to cross over at say 120Hz (atleast), and extend evenly till about 30-40Hz. Another issue to take into consideration is my room which is about 12x12. I realize that its not ideal, but i've to work with what i've got.
I have a rythmik DS12 sub that works great in my living room, but for some reason i couldn't get it to work in this 12"x12" room. I tried moving it around, but still i never got it to work, so moved it back to my living room.
A friend of mine has a pair of tangband W69 that i can probably use in a push-pull or isobaric configuration in a small box... but was wondering what other possibilities are out there for me?
So to summarize, I need a subwoofer that will work within these limitations:
- Can be crossed over at around 120Hz
- Should go down to 30-40hz
- Has a small footprint
- Work in 12'x12' room
- Can keep pace with line arrays
Thanks!
Old 21st August 2009, 01:28 AM   #2
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Cacophonix,
I haven't tried these myself, yet, but it seems they are looked upon rather favorably. They're on my list of "projects-to-do."
http://www.parts-express.com/project...t=TheTriskaSub
and then these are supposed to be pretty good too...
http://www.rjbaudio.com/Cerberus/cerberus.html
Mike
Old 22nd August 2009, 09:17 AM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by Cacophonix View Post
..A friend of mine has a pair of tangband W69 that i can probably use in a push-pull or isobaric configuration in a small box... but was wondering what other possibilities are out there for me?
- Can keep pace with line arrays..
Thanks!
Don't know if the Tangband drivers in my suggestion are the right ones but as can be seen in the submitted pictures:
This T-TQWT can be XO:ed at 120 Hz and fulfills the requirement:
'Should go down to 30-40hz' and has a small footprint less than a sq.foot.
IMO: This sub delivers very good SQ and should '..keep pace with line arrays..' as any matching SPL would be set by using the volume knob of the required sub-amp.
b
Old 23rd August 2009, 05:47 AM   #4
Thanks a bunch, guys!
Mike, The PE sub looks interesting, and cheap
bjorno, thanks for your response, those are the exact drivers that i had in mind.
W69-1042J are the drivers that i have access to locally... and was kinda on using these drivers, to see how they integrate with my arrays.
I am interested in the push-pull/isobaric configuration since they tend to be on the smaller side of things. Has any one tried these drivers in this configuration?
Size is a huge factor here, since my room is damn small, and i've a pair of arrays in there, plus my PC workstation. So i'm really looking for sth under 2cuft. The T-TQWT, though having a small footprint, is too tall.
Old 25th August 2009, 04:08 PM   #5
zobsky is offline zobsky  India
zobsky's Avatar
For what it's worth, I've built a T-TQWT with the W69 and it worked nice down to 30 - 35 hz i npractice. If I build again, I'd look at increasing the terminus area (sounded just a little bit restricted)
http://zobsky.blogspot.com/2009/04/t...pped-pipe.html
I think he wants something smaller, though (he has access to my drivers) . Need to brainwash him into believing that box subs are inferior
"Any fool can know. The point is to understand" - Albert Einstein
Old 25th August 2009, 05:01 PM   #6
Originally Posted by zobsky View Post
..For what it's worth, I've built a T-TQWT with the W69 and it worked nice down to 30 - 35 hz i npractice. If I build again, I'd look at increasing the terminus area (sounded just a little bit restricted)..
Hi Zobsky, Look at the picture where yours and the one I suggested Cacophonix
using the same driver input power level and space angle is shown.
..I think he wants something smaller, though (he has access to my drivers) . Need to brainwash him into believing that box subs are inferior ..
Agree, Box subs are not the to SQ
b
Old 31st August 2009, 04:28 AM   #7
I have almost decided to go with 2 subwoofers instead of an isobarik design. Considering the following shape to suit my room -
The cabinet shape will be triangular (wedge shaped) so that i can push it against the wall. The vent will either be facing up or down. I'll cover the cabinets with burlap so that they can blend with the sound absorption panels i have in the corner. Will probably buy a cheap used amp to fire these up.
Should the driver be closer to the carpet floor or higher up?
Also, more importantly, has anyone tried this kind of a cabinet before?
Old 31st August 2009, 04:42 AM   #8
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Stereo pair or just a single cabinet?
Jim J.
Old 31st August 2009, 05:01 AM   #9
frugal-phile(tm)
planet10's Avatar
Not cheap, but i think suited to your ap... i'm just finishing a build of 4 12" sealed cubes with SDX7 & the Foster plate amps Jack Hidley is selling so cheap... Performance as required and small.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st August 2009, 12:53 PM   #10
Stereo pair.
recommendation needed - is the real? aeroman1003 Everything Else 5 4th January 2008 11:35 PM
SPICE program recommendation needed hifimaker Parts 4 20th March 2007 11:24 AM
Recommendation needed.. Dxvideo Chip Amps 10 13th December 2006 01:02 PM
Re: Recommendation on capacitor value needed Sunsun22 Solid State 14 2nd July 2005 11:43 AM
Recommendation needed for Inf. Baffle for Miata... eRiCdWoNg Multi-Way 0 24th February 2004 12:10 AM
Page generated in 0.11276 seconds (83.21% PHP - 16.79% MySQL) with 11 queries
