I am looking for a box design for a HERTZ HX300D speaker.
It will be used as a surround sound sub woofer in a rather large room, about 10 x 15 meters. I will try to supply other info if needed. Thank you. Roelof |
#2 |
Hi R,
Here is a suggestion for the HERTZ HX300D driver: picture 1(2)-2(2) b |
#3 |
HI B, thank you for the detail. I just have a bit of a problem trying to work out what the drawing is all about. The details of the box I mean. The details are very vague or maybe I am I bit to dumb to understand. Please help me a bit more. Thank you.
Roelof |
#4 | |
Don't blame your self for poor understanding of my simple drawing: You are of course right: the drawing is very vague... I checked the drawing again and found one faulty number, now revised. This can be seen in the slightly updated picture 1(1) here below. My simple drawing is just an example how to fold the HR simulation if happen to be a straight pipe, i.e. a T-TQWP a.k.a. T-TQWT. The suggestion was to pick one of the L length's between 2,6 m to 3 m. As this length is unknown, I left out the vertical dimensions to be a calculation exercise for any user of this particular drawing. For a first trial: use L/4 for the internal height and calculate if all sums up to within about 5 % of the chosen L, IMO good enough. b 1(1) |
#5 |
Hi B,
Thanks again for the info. I can build that box if I can work out where the supports must be. Please excuse me, I am a retired electrical eng. and not an audio guru at all. This is my first speaker box building excersize. What is "L" If I take it as 2,8 m and make the inside of the box 700mm. That just looks like a good guess to me ? Thanks again Roelof |
#6 | |
2.8 m length is a good choice,see the pictures where also a OD.Offset driver TL is plotted for comparison. This could be a good option to use if the speaker is placed closely to a short wall corner when over-emphasizes of low end modal FR is expected. b |
#7 |
Hi B,
Thanks for the info. I am going to study this a bit and will get back to you if there are problems (and you do not mind) Regards Roelof |
#8 |
Hi B, the bracings as shown, are these flat pieces on the left and right, or are they in the centre of the box? (looking at the box from the face of the speaker)
Kind Regards, Roelof |
#9 | |
Yes they are all flat vertically oriented pieces dividing the box in half looking from the face of the speaker where the volume loss can be ignored if only occupying a couple of percents of the total internal volume. b |
#10 |
Hi B, Sorry to be a pain but some more questions: The booklet that comes with the speaker says that there should be 50mm gap between the rear of the speaker and the box to allow for air movement through the hole in the magnet.? The devider going up to the sub L23 seems to stop very close to the sub. Your drawing shows lines going up to the back of the magnet. Are these flux lines? there is no mechanical piece on the speaker as indicated on the drawing? If you leave the dotted lines out, that is what the speaker looks like. Thanks for the effort, Roelof
| subwoofer under bed | Potato42 | Subwoofers | 7 | 13th January 2009 02:21 PM |
| subwoofer project, which subwoofer? | Davlaf | Subwoofers | 12 | 9th November 2006 03:59 AM |
| Subwoofer crossover / subwoofer module design | derMichi | Subwoofers | 4 | 20th April 2006 10:31 AM |
| how to connect a non powered subwoofer to a stereo system without a subwoofer output | JSD777 | Multi-Way | 4 | 20th September 2005 03:19 PM |
| I need help with subwoofer deisign: HUGE inexpensive subwoofer | hottyson | Subwoofers | 16 | 4th May 2004 03:51 AM |
| Page generated in 0.12297 seconds (86.03% PHP - 13.97% MySQL) with 11 queries |
