Old 19th April 2011, 08:02 PM   #11
GM is offline GM  United States
GM's Avatar
Everything you need to know is in the HELP file, but this tutorial lays it out a bit better: WinISD Pro Tutorial and Download (A detailed guide on how to use WinISD Pro) - Home Theater Forum and Systems - HomeTheaterShack.com
The program can reconcile even major discrepancies I've encountered with some manufacturer's published 'wishful dreams'. Actually, this driver only has a few off by fractions compared to its math derived 'ideal', i.e. it was accurately measured.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th April 2011, 08:40 PM   #12
digits's Avatar
Hey man I'm subed, thanks for starting the thread.
Old 20th April 2011, 02:45 PM   #13
YouTube - WinISD-entering-parameters.avi
Here is a link to a you tube about entering the data. The sidebar shows some other box design vids. using other programs.
I will give it another whirl. But I may be just having a three into two won't go problem. The old Roland belongs in an OB. I've been told that repeatedly and I think that finally I will give that a shot. Once done I can re-cut the OB for a Karlson. My move to Karlson is to get the box size down from floor standers. Plus the K's look interesting. I have one made but not tuned.
Old 20th April 2011, 03:10 PM   #14
digits's Avatar
So, once you know the optimal volume of the unit (sealed box), how do you determine the optimal dimensions?
Old 20th April 2011, 06:33 PM   #15
optimal dimensions are where standing waves occur at different freqvencys.
Suposedly one can just use 3rd root of 2 as the ratio of sides.
if A dimension is 1, then B should be 1,26 , C should be 1,59 or so.
But actualy for subs the ratios do not mather that mutch, standing waves will be formed at out of band freqvency for the sub.
Old 21st April 2011, 04:17 AM   #16
digits's Avatar
My woofer can go from 30 something to 3000Hz, I want to let it handle 30 to 2000 untill I get midrange drivers.... would the dimensions become more critical?
Old 21st April 2011, 04:20 AM   #17
GM's Avatar
Well, the smallest cab would be an OB, but I prefer the extra control of some form of TL for high Qt drivers. Which version of Karlson will such a high Q driver work in?
GM
Old 21st April 2011, 02:30 PM   #18
GM's Avatar
.......would the dimensions become more critical?
Correct, think of the cab as a very small room with all the same modes as a large one, just beginning higher in frequency.
GM
Old 24th April 2011, 03:40 AM   #19
Zero D is offline Zero D  United Kingdom
Smile WinISD without tears
Nice to see people making use of the thread
I wish i'd called it "WinISD without tears" or something similar, instead of "How to correctly use WinISD"
I realise there are more ways than mine to successfully use WinISD, but so many people seem to have, or have had problems entering the parameters correctly, and therefore making errors & getting frustrated etc, i felt that by making this thread with lots of clear screeshots etc, would enable them to spend more time designing, and more quickly, with a sure fire way that works and gets results
are these capacitors installed correctly moss99 Everything Else 4 11th March 2009 07:53 AM
Am I using Unibox correctly? zimjj Multi-Way 0 7th February 2009 11:26 PM
Am I using UniBox correctly? needtubes Subwoofers 3 12th June 2005 02:02 AM
Are we looking at distortion correctly? mashaffer Solid State 24 14th July 2004 03:04 AM
Is my DCX2496 funtioning correctly? Lito Digital Line Level 2 11th February 2004 08:15 PM
Page generated in 0.10617 seconds (75.70% PHP - 24.30% MySQL) with 10 queries
