#2 |
The driver needs to be offset at ~ 1/3rd the length of the pipe;
a gradual taper is better (fewer standing waves); to get the length try the calculator posted in post 13 of this thread: need help with TL calculations
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
frugal-phile(tm)
A couple things.
1/ it should not be tuned below Fs 2/ offset is approximately 1/3... optimum depends on taper 3/ i suspect yours is too long with eo small a cross section. What driver? dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Agree 100% with planet10. For this driver and your CSA it would be better if choosing a length between 2 and 3 m and IMO best if designing a T-TQWT. See picture 1(1) b |
#5 |
Ok, what would you recomend i use as my length, and ratio of taper?
the Fs of the driver is 27hz Sam. |
#6 |
Wow bjorno! thank you! so would that design with say a 2.5m lenth and those ratios be a good starting point then? those responce curves look good to me
confused |
#7 |
Great work as always Bjorno!
FYI, I uploaded this driver's WinISD file for anyone wanting to try more mundane loadings: http://www.hometheatershack.com/foru...tz-es250-4.wdr GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#8 |
Thanks guys, it will be built over the weekend.
should i place the driver at the 1/3 of the length? |
#9 |
Well its done! and oh my!
Its not the loudest, but omg does it play flat! the into to put on - young jeezy is insane it goes from 40-35-30-24 hz and all of them are hit with aurthority and subtleness, the sound on some tracks it astounding, thank you to all envolved and everyone who helped should i wad/stuff it? |
#10 |
I'm not clear on what you actually built, but it depends, though if you're pleased with it as is, probably no point in 'fixing' what isn't 'broke'.
GM
| Design of Transmission line speakers | ArjenShenzhen | Multi-Way | 4 | 16th June 2009 07:33 PM |
| Transmission line design?? | Dominick22 | Subwoofers | 1 | 15th September 2006 07:24 PM |
| recent transmission line design? | Havoc | Multi-Way | 6 | 31st December 2005 09:20 AM |
| MTM Transmission Line Design-Where To Consider Center Of Speaker | kelticwizard | Multi-Way | 4 | 8th December 2005 02:30 AM |
| Meadowlark Swift Bass Transmission Line Design? | dtm1962 | Multi-Way | 3 | 6th August 2003 03:03 PM |
| Page generated in 0.09519 seconds (77.07% PHP - 22.93% MySQL) with 11 queries |
