Looking for an high efficiency sub driver (93db+) which can do 115db at 25 hz, and a maximum 150 liters enclosure. Around 300 usd per driver / pair.
Any recommendations? |
#2 |
#3 | |
#4 | |
Seems you are wanting a driver that will break Hoffman's Iron Law an do it for small $. Unlikely to happen. Go look at Illka's subwoofer tests and see what can actually be achieved. Sub tests. |
#5 | |
Ive modelled Eminence kappalite 3012LF in bassbox, and it gets pretty close if the simulations is correct. Ill take a look at that link though!
#6 |
I would look at either PrecisionDevices or RCF
Both have a few with low Fs around 27hz And tune for 30hz As I recal they have better Xmax than Eminence Pro woofers with even more Xmax cost more Why so loud anyway Dont you want to keep you hearing for long I can tell you that damaged hearing can be very painful Besides, a building could easily be damaged as well Such SPL are for outdoor use, or at least not small rooms |
#7 |
JBL 2226H seems to handle my demands. At least according to my simulations.
I allready use a pair in my mains, but they are about to be switched to something smaller, so I might as well use one for sub duty
#8 |
Driver 40hz Fs and box tuned to 25hz ?
Xmax 7.62mm ? Are Xmax one way or p-p ? |
#9 | |
#10 |
In the 2226H sim, it says 'No of Ports =0". What did you use for porting?
| UK source of inexpensive 3" or 4" driver - high efficiency | sreten | Full Range | 9 | 23rd November 2005 03:15 PM |
| is tuning at 25Hz too high? | Matt Neilson | Multi-Way | 22 | 1st July 2004 02:09 AM |
| 12" driver with big Xmax,low Fs, & high efficiency? | WolfmanX | Multi-Way | 18 | 26th November 2002 11:10 PM |
| Page generated in 0.10452 seconds (80.67% PHP - 19.33% MySQL) with 10 queries |
