Peerless 10" XXLS 830843
Old 26th July 2009, 08:57 AM   #1
burger007 is offline burger007  Australia
Default Peerless 10" XXLS 830843
Hi, ignorant newbie here...
Has anyone built a box for this driver (or any of the XXLS 10" from Peerless)??
I tried using WinISD, but I could only find an alpha version, which is giving me some trouble - I enter the specs of the 830843 and WinISD keeps telling me some of the values are not correct. These values I got from Tymphany's website..
Any help/advice or suggestions on a box design would be appreciated.
Old 26th July 2009, 01:13 PM   #2
Stu is offline Stu  Australia
Which values are incorrect?
That's one of the annoying things about WinISD alpha, but it's pretty easy to fix. Just delete one of the conflicting values and let the program calculate it instead. You might get some slight rounding errors, but it should be pretty close.
Just trying the 830843 myself, I left Qts blank and entered only Mms, BL, Le and xmax in the other parameters.
This gives the following:
Qts = 0.447
Cms = 0.5072 mm/N
Rms = 1.38989 Ns/m
Re = 5.851
Dd = 21.02 cm
Sd = 347.1 cm²
While the specs give:
Qts = 0.44
Cms = 0.51
Rms = 1.39
Re = 5.8
Dd = 21.2
Sd = 352
They're all pretty close (you can get closer if you use Qes = 0.465), so it's not going to make a huge difference, particularly if you go sealed (as I think the 843 is designed for).
Old 26th July 2009, 03:08 PM   #3
GM is offline GM  United States
GM's Avatar
Tutorial:
http://www.hometheatershack.com/foru...inisd-pro.html
Downloadable driver files:
http://www.hometheatershack.com/foru...pro-files.html
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th July 2009, 04:03 AM   #4
Thanks to you both, I'll look at the tutorial and try it with the calculated values.
Cheers
Old 27th July 2009, 08:28 PM   #5
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Yes, Ive used all the XXLS 10" drivers in different designs.
A couple of different HR simulations using the Peerless 830843:
1(3)-3(3)
b
1(3)
Old 27th July 2009, 08:30 PM   #6
2(3)
Old 27th July 2009, 08:32 PM   #7
3(3)
Peerless 10" XXLS 830843Hide this!Advertise here!
Enclosure - 10" Peerless XXLS Guy Incognito Subwoofers 4 23rd November 2007 08:50 AM
FS: (2) Peerless 12" XXLS 830845 tf1216 Swap Meet 7 24th October 2005 12:24 AM
Peerless XXLS 12" DVC (830837)- replacement for PE Dayton 12" DVC 295-185? tktran Subwoofers 2 14th August 2005 03:04 PM
Copyright ©1999-2017 diyAudio
