I've ordered an AESpeakers TD18H: http://aespeakers.com/shop/catalog/p...products_id=71
What would you do with it? My guidelines/rules: Bandwidth: roughly 30-100hz High spl for PA usage, though the response still needs to be "hifi" Box must be portable (I'll let you decide what that means) No inductors unless you pull of something really special with it. Xmax 14mm, Xmech 20mm. - Nick McKinney said it's safe to Xmech I've attached hornresp screenshots of the sort of thing I'm looking at currently. It's a 326L (internal) tapped horn. SPL chart is with 1200 watts, just scraping under Xmech. I haven't looked at folding it yet. Thanks! |
#2 |
Response graph
#3 |
Hi fb,
Looks interesting. If you can live with a larger box, here is the input for a similar tapped horn with a few edited dimensions. Regards,
Oliver |
#4 |
Thanks tb46
It seems a versatile driver - if it doesn't work for me in a horn I can still get respectable output vented Thanks for the sim - I have to work out how big I can go - yours is flatter, with less group delay down low. I'm also looking at transmission lines / T-TQWT |
#5 |
Here's a 300L tapped pipe / transmission line / whatever it's called.
Response looks wonky but excursion is smaller for the same SPL. |
#6 |
Further to the last input screenshot.
Uses this inductor: http://www.erseaudio.com/Products/XQ.../EAV79-12-8000 |
#7 |
And a quick sketchup fold.
#8 |
261L Tapped horn:
Any comments? Net volume is the same as the vented enclosure, gross volume would be a little larger. Cutoff is a little higher, but hopefully I can bring that down as I approach a final design. Grey line in the output is the vented box. |
| Page generated in 0.09465 seconds (76.31% PHP - 23.69% MySQL) with 10 queries |
