Old 3rd July 2009, 07:20 AM   #1
Send a message via Yahoo to mikelm
Default what sounds best . . . Low Qts in small cab or higher Qts in bigger cab
I wonder if some of you have a preference in this regard.
assuming all other thing more or less equal
I would appreciate ur opinions
thx
Old 4th July 2009, 10:47 AM   #2
Moondog55's Avatar
OK
How about medium "Q" driver in a medium size box.
Not meant to be quite that snide if by medium "Q" you mean between 4 & 5 and a Qtc f 0.8/0.9
But my preference isn't every-ones and I find this combination needs a driver with Fs of around 18/20 hz
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 4th July 2009, 11:28 AM   #3
For real bass the " iron law" says to use a big cab or be prepared to use a lot more power!
Old 4th July 2009, 11:43 AM   #4
sealed or vented?
regards Andrew T.
Old 4th July 2009, 11:45 AM   #5
sealed
Old 4th July 2009, 11:48 AM   #6
I'll guess and say if both the large and the small interpretations are built to achieve the same Qbox then they will sound similar.
regards Andrew T.
Old 4th July 2009, 11:54 AM   #7
I'm wondering about the effect of the higher acoustic pressure inside a smaller box and whether that would have an audible effect.
I have have a notion that a larger box may sound more relaxed because of the lower pressures involved so I wanted to get feedback from anyone with experience of this.
mike
Old 5th July 2009, 12:30 AM   #8
Moondog55's Avatar
Mike I don't know if more relaxed is the term I'd use, but if the floor space is available go for the bigger box.
using sealed box with a driver with a low "Qts" will not give deep bass how-ever.
For sealed boxes I'd not use any driver with a "Qts" below 0.33 myself but that is only my opinion, and how it sounds in the room is highly variable too
Old 5th July 2009, 01:14 PM   #9
thanks to all for your comments
I am thinking of:
1 x Dayton 12" Titanic Mk3 4 ohm in about 100 litres per channel.
or if I am feeling I bit more crazy
2 x Dayton 15" IB385-8 on open baffles per channel.
cheers
mike
Old 5th July 2009, 01:35 PM   #10
both will need some form of equalisation to get bass from the installation.
That equalisation will reduce the peak SPL available from the speaker.
The bigger the box the more peak SPL available.
But that does not get close to answering the original question.
Does size affect the sound?
regards Andrew T.
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 06:40 AM
Wanted 10,000uf or bigger @100v or higher nikonfanatic Swap Meet 1 8th September 2003 07:32 PM
Characters getting bigger and bigger Elso Kwak Everything Else 11 31st May 2003 10:43 PM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
Page generated in 0.10243 seconds (87.10% PHP - 12.90% MySQL) with 10 queries
