Old 29th June 2009, 02:09 PM   #1
Default bass-reflex with 2 different ports?
Helo everyone, My name is Andrew.
I'm an "avarage DIY guy", I did build a few subs and a few pair fo speakers, none of them where anything special.
I came across a few quite good simulations software, and my interest now is to find out what happens if I have a woofer in a box with more than 1 port.
Supposedly if they are identical then it is an easy task to find out. Actualy the simulation softwares did give a cleart answer.
but.. what if they are not identical?
is it possible to add a secund port to an allready ported box, to introduce a nother resonance in the passband, and reduce cone excursion/extend low freqvency response?
I did allso found a few quite well made excel spreadsheets that can simulate a driver transfer function in a ported box, I guess if someone could help with the math formulas regarding to simulate a box with 2 different ports and a driver I could actualy do a simular thing, so I can see visualy what would happen with that sortha aligment.
I understand that supposedly the 2 ports would interfer, but maybe there would be a passband (I guess a narrow passband) where the aligment could be used. (may require some qute sharp filters to limit bandwidht, and may require a notch filter too..)
well, thats all my question
Old 29th June 2009, 04:53 PM   #2
chris661's Avatar
Multiple ports with different tunings.
I'll let you off, for now...
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 29th June 2009, 08:10 PM   #3
WOW!
I don't know how you have done thatone, belive me I did search the board with my keywords.
I guess admins can remove my thread, and sorry for opening it. I'm from hungary, and not a too good english student. I think I might had used incorrect search string...
Anyways Thank You for pointing that thread out, it contains the valuable information I was seeking.
one bit thing, I hope it ain't a problem if I ask it here..
Is aperiodic bi-chamber same as described
here?
Old 29th June 2009, 09:01 PM   #4
GM is offline GM  United States
GM's Avatar
Well, ideally it would be its own thread, but a search engine will find it regardless........
Aperiodic means 'without period' or in the case of a speaker, it means it has no appreciable impedance peak at Fb, so while that cab is a double chamber reflex, to make it aperiodic would require considerable stuffing to flatten its impedance peaks.
Typically, a true aperiodic speaker is a well stuffed maximally flat alignment TL, but often you'll see a reflex speaker alignment that's been somewhat stuffed listed incorrectly as aperiodic, or more correctly, ~aperiodic, since it only suppresses the impedance peaks just enough to smooth out its response.
BTW, I often have better luck finding stuff on this and other forums by using Google than I do using the various forum's 'search' function.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 29th June 2009, 10:11 PM   #5
hmm, I see.
You surely seem to have a lot of knowledge
Actualy do You see any chanse I could find any material related to dual -chamber ported system shown at the link?
I would be intrested to find some ways to simulate it, with the ability to vary the tuneing freqvency.
from the post You have found for me (thank You again)
I learned that if I only have 1 chamber, with multiple ports it is not going to work as I was thinking it would.
but how about the dual-chamber systems?
I mean.. 1 chamber with the driver and 1 port towards the room, an other port connecting the chamber to an other chamber, and this secund chamber allso vented to the room. I would be intrested in learning how to simulate the response curve of such system, to be able to see what happens if I varry the ports.
realy a shame, but no mather how hard I search, only suitable/related pages I find on the net are showing transfer characteristics of sutch system, and.. basicly they doshow up with an additional peak in the resistance curve.
Old 30th June 2009, 03:09 PM   #6
GM's Avatar
Only this: http://www.claudionegro.com/projects...r/dcr/dcr.html
The only program I'm aware of that can probably sim this is AkAbak, which has a steep learning curve as the price you pay for such programming flexibility: http://www.randteam.de/_Software/AkA...ad-AkAbak.html
GM
Old 4th July 2009, 02:54 AM   #7
well, I tryd a few of the available simulation software, LSPCAD was allmost close to it, but..
nope, no mather how hard I was trying to I could not get the thing to work as it should..
Too bad I can't find calculation formula anywhere..
anyways might have to do some DIY experiments to see how things are working..
Covering bass ports? revans Everything Else 7 17th April 2009 10:10 PM
Two ports in a 2-way bass-reflex speaker alvinlim Multi-Way 3 15th February 2006 10:41 AM
Bass reflex theory: multiple ports Qp TG Multi-Way 3 18th November 2005 05:34 PM
Nice looking reflex ports mark.carline Multi-Way 2 10th May 2004 06:39 PM
bass reflex? GAK Multi-Way 2 23rd October 2001 03:04 AM
Page generated in 0.08446 seconds (85.46% PHP - 14.54% MySQL) with 10 queries
