HornResponse Maximum SPL - diyAudio
Old 21st June 2009, 02:45 PM   #1
Default HornResponse Maximum SPL
I'm trying to figure out if the speakers I'm using (Delta12LF) will run out of xmax at the highest level. This enclosure has 4 drivers and each have an xmax of 4.8mm and xlim of 13.5mm. Maximum electrical power from amplifier is 2000w. What should I input for maximum displacement? How accurate is HornResponse calculating maximum SPL?
Old 21st June 2009, 02:55 PM   #2
of course the drivers will run out of Xmax at highest input.
Specify the frequency range you are interested in.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 21st June 2009, 02:59 PM   #3
40-100hz. Does the max displacement equal 4 x 4.8mm? 4 x 13.5mm?
Old 21st June 2009, 03:07 PM   #4
horn response allows multiple drivers.
regards Andrew T.
comment on hornresponse sim Milkduds Multi-Way 2 9th November 2008 07:34 PM
altec 515 and hornresponse patriz Multi-Way 3 21st August 2007 11:14 AM
phase rotation with hornresponse patriz Subwoofers 2 13th June 2006 10:59 AM
DIY Electrostatic - maximum safe db ? rick57 Planars & Exotics 43 3rd June 2006 05:26 PM
help with hornresponse patriz Multi-Way 21 3rd April 2004 12:00 PM
Copyright ©1999-2017 diyAudio
