designing a sub and fullrange box for several speakers...
Old 2nd July 2009, 11:01 PM   #111
mulletdude is offline mulletdude  Canada
Hey Cal how do i go about sending them to you ?>
Bigger the better... unless you like peace and quiet...
But we can fix that too.
Old 3rd July 2009, 12:04 AM   #112
pic 1
Old 3rd July 2009, 12:05 AM   #113
and number 2
Old 16th July 2009, 11:20 PM   #114
ok i have another question now... can i just put the other 15 inch sub in this enclosure i built without dicking around too much because i have very limited materials. like basically put it in the top of the box pointing up right behind the other drive. wired in parallel. so that the 2nd driver would be right where the drinking glass is in the above picture.
Old 17th July 2009, 03:52 AM   #115
bottomfeeder is offline bottomfeeder  United States
its a matter of "do you have enough cabinet volume and enough amp "
Old 17th July 2009, 04:00 AM   #116
Are you using the plate amp ?
what model?
Old 17th July 2009, 05:31 AM   #117
901Fixer is offline 901Fixer  United States
I would put it on the other end just like you have the one installed. If your amp can handle whatever load these drivers give you wired in parallel then sure. Are they both 8ohm? If so then they'll be 4ohms in parallel.
Any additional material you end up with try and make some bracing or support for the box and each driver if you can. The less the box resonates the more SPL you will have not to mention cleaner sound and no unwanted noises.
designing a sub and fullrange box for several speakers...Hide this!Advertise here!
Designing speakers for guitar modeling amp JWK Instruments and Amps 8 3rd June 2008 04:58 PM
Designing a fullrange dipole? Kensai Full Range 10 6th January 2006 04:49 PM
www.Fullrange-Speakers.com??? theNoid Full Range 11 22nd September 2005 10:38 AM
Designing PA speakers nicksmurf Multi-Way 34 16th August 2004 12:02 AM
help with designing speakers Wagener Multi-Way 3 29th May 2004 08:13 PM
Copyright ©1999-2017 diyAudio
