Old 29th June 2009, 12:18 AM   #21
whats your plan?
You still need to build a cabinet around a driver(or both) , if you close the top you basically are sharing the cabinet with both drivers, but that cabinet is not big enough for 2 drivers,
I would recomend building this into a isobaric, what you would have to do is mount both drivers on 1 side (both speaker cones facing each other) I use long bolts with sheetmetal tabs on them , so when you tighten one it tightens the other .
You need to wire one driver out of phase (or they will cancell each other)
What you will gain is the woofer is fooled to beleive the cabinet is twice the size .
Old 29th June 2009, 12:20 AM   #22
ok what makes you think it is not big enough for both drivers like this... i built it 2 times the size of one drivers recomended enclosure size...
so what you want me to do is make this isobarik and have it look gotty because both drivers are on the same side.
Bigger the better... unless you like peace and quiet...
But we can fix that too.
Old 29th June 2009, 12:43 AM   #23
Originally posted by mulletdude
ok here it is now its small enough to attach.
Those drivers are mounted Push Push. They should be wired the same as each other so when one cone moves outwards so does the other. The positive lead of each channel should attact to the positve terminal of each driver. If the displacement of the box is 2x what one driver needs then it should work fine.
If the drivers are wired opposite each other, positive lead to the positive on one driver and positive lead to the negative on the other then there will be cancellation and SPL will suffer.
Old 29th June 2009, 01:25 AM   #24
ok thanks for that i guess they are push push... and they are driven like you said but from 2 outputs on my amp... is there any way to get more SPL from this setup short of getting more speakers
Old 29th June 2009, 01:52 AM   #25
so if they are push/push they are both firing towards each other ?
if so where is the cabinet for the drivers ?
I guess you are firing the cones towards the magnets (backwards from normal) .
So you are setup with a double size box with 2 drivers ?
As far as spl it matters on 2 things ..
How much amp you got for it and what the speaker likes .
You could build 2 ported boxes (dont try and combine the internal)
just put a divider and a port in each chamber .
If you were to build one like mine you could use a smaller box .
But 2 drivers set up where you can see both cones will give you more spl .
Is this going in a car ?
Old 29th June 2009, 02:00 AM   #26
The cabinet looked small (I guess it was a illusion)
On a isoberic you ONLY see one driver , the other one is next to it
(clamshell design) if your cabinet was a isobaric you could have 4 drivers running .
What is your cubic feet inside your cabinet ?
Old 29th June 2009, 02:08 AM   #27
the dimensions are above and are as follows 21.25*15.5*15.25
Old 29th June 2009, 02:10 AM   #28
I was wondering ..
My iso is wired one amp side per woofer , but have you ever tried to series the woofers and run one amp lead to the combo ?
If so does it sound good (as long as the amp is strong enough) ???
Old 29th June 2009, 02:12 AM   #29
the amp i currently have is only 100 watts per channel so it would make more sence doing it theyt way i am.
Old 29th June 2009, 02:16 AM   #30
thats 2.95 cubic feet , that gives you 1.47 per driver .
Should be fine .
I never tried a box like yours , I usually build 2 individual boxes.
Is this for a car or a home sub ?
Designing speakers for guitar modeling amp JWK Instruments and Amps 8 3rd June 2008 03:58 PM
Designing a fullrange dipole? Kensai Full Range 10 6th January 2006 03:49 PM
www.Fullrange-Speakers.com??? theNoid Full Range 11 22nd September 2005 09:38 AM
Designing PA speakers nicksmurf Multi-Way 34 15th August 2004 11:02 PM
help with designing speakers Wagener Multi-Way 3 29th May 2004 07:13 PM
Copyright ©1999-2013 diyAudio
