designing a sub and fullrange box for several speakers... - Page 11 - diyAudio
Old 1st July 2009, 07:19 AM   #101
Originally posted by mulletdude
open baffle... read 901fixer's above post
wait for 901's replie .
I have never heard a OB that sounded right , and the ones that do are usually a single sub (probebly to avoid cancellation)
Old 1st July 2009, 07:20 AM   #102
Moondog55's Avatar
For an OB (Open Baffle ) just a BIG bit of plywood that is bigger than your woofer will do, although that is just for starters.
15inch woofer so I'm thinking that a 1/2 sheet of ply cut in two bits may do.
Woops is ply in the US the same size as here? 1200mm * 2400mm, that's 4 by 8 feet, so a half sheet is 4 *4 so cut that's 24 inches by 48 inches, add short side wings about 3 or 4 inches deep.
Both side should be the same driver tho if using in stereo or your front L & R
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 1st July 2009, 07:23 AM   #103
Moondog55's Avatar
Best plan is to put all subs in a single cornor
No spread em out, randomly spaced around the room sometimes works so much better.
My HT has 5 subs at the moment; 3 in front one in a rear corner and one in a front corner for a little bass boost
Old 1st July 2009, 07:29 AM   #104
dont forget MoonDOg im not using this for HT just simply for alot of bass re-inforcement fro music at high SPL's
Bigger the better... unless you like peace and quiet...
But we can fix that too.
Old 2nd July 2009, 08:26 PM   #105
okay so heres what i ended up building... a sealed box that is 4 feet long and the internal dimensions on the end are 17 and a quarter by 17 and a quarter. do you think i could get away with putting the 2 speakers in this... it sounds really good with the one so far.
Old 2nd July 2009, 08:32 PM   #106
Thats around 8 cuft and you need at least 3 per so you should be ok. You really need to brace a box like that and try not to mount the drivers centered or have any equal dimensions. Where is the one mounted on the box? You could mount the other one directly behind it in a Push Push configuration and gain some SPL. Where in your room will this be located?
Old 2nd July 2009, 08:38 PM   #107
ill post a picture or two of it in a minute but the one is in the end... centered because i was afraid i wouldnt have enough room around the driver to screw the end on. its right beside my chair currently ..ill put a pic of that too... how do you guys put up such huge pictures all the time? i never seem to be able to upload a big pic because of the size
Old 2nd July 2009, 09:05 PM   #108
ok please plesae tell me how you put up so big files...
Old 2nd July 2009, 09:06 PM   #109
I'd mount the other one on the other end but you need to make an "X" brace that runs the length of the box and braces all four sides to each other. The brace should be made out of plywood with at least half of the wood removed or you can use pieces and strips. Here is a link to give you and idea of what I'm talkin' about. The brace needs to butt up to the back of the magnets so both drivers are coupled to each other thru the brace.
http://homepage.mac.com/planet10/CSS/push-push-SD12.pdf
Old 2nd July 2009, 09:21 PM   #110
Speakerholic
Cal Weldon's Avatar
Max size file is about 100K. Reduce the pics or send them to me and I will a little later.
planet10 needs your help:
Let's help Ruth and Dave
Designing speakers for guitar modeling amp JWK Instruments and Amps 8 3rd June 2008 03:58 PM
Designing a fullrange dipole? Kensai Full Range 10 6th January 2006 03:49 PM
www.Fullrange-Speakers.com??? theNoid Full Range 11 22nd September 2005 09:38 AM
Designing PA speakers nicksmurf Multi-Way 34 15th August 2004 11:02 PM
help with designing speakers Wagener Multi-Way 3 29th May 2004 07:13 PM
Copyright 1999-2017 diyAudio
