help! LARGE tapped horn
Old 18th June 2009, 04:11 AM   #1
bubblersound is offline bubblersound  United States
Default help! LARGE tapped horn
I'd like some input on my single fold tapped horn using B&C 15TBX100's. Can someone double check the hornresp numbers and the layout I've shown. Included is a pic of the sketchup model.
Old 18th June 2009, 06:50 AM   #2
Wrong HR data. I can't figure out how to edit the post so here's the new info...
Old 18th June 2009, 03:05 PM   #3
Rademakers is offline Rademakers  Netherlands
It looks like a nice and easy to build design. Personally I don't think the S3-S4 section will work out to be the way you simulated it.
Because you're using 3 times 8 Ohm drivers, 2.8 V translates into 3 Watt's because it's actually into a 2.66 load.
Wkr Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 18th June 2009, 05:17 PM   #4
MaVo is offline MaVo  Germany
you might want to reexamine this design. its pretty big, for good performance a mouth of 2500 or even less cm² should be enough. the bend is kinda extreme, it could behave totally different from what you simmed. the sim itself is pretty bumpy in the frequency response, aim for flat. if you want a horn of this size, look at some premade front loaded design like the labsub.
help! LARGE tapped hornHide this!Advertise here!
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 10:22 AM
Evolution of the Tapped Horn Don Snyder Subwoofers 30 18th August 2010 01:06 PM
tapped horn wiki? weikertball Subwoofers 0 31st May 2008 05:20 PM
