Would a pair of drivers in an isobaric arrangement (cone to cone) work in a tapped horn? Assuming the throat area is large enough to accomodate the rear of one driver of course. Can this be modeled in Hornresponse by just adding the other driver in the driver arrangment window?
#2 |
Hi
FYI,Here's an example showing an isobaric T-TQWT HR simulation I hesitated to post as the thread* starter seems to be gone? * Using Monacor IMG Stageline SP385-G as subwoofers for movies? b |
#3 |
I'll guess that the 107dB/m is for 8W input power or ~98db/W/m when specified conventionally.
It also appears that @ ~35Hz the speakers run out of Xmax @ ~12W, giving about 109dB/m max SPL. Can you improve on either the 98dB or the 109dB by going to dual/parallel rather than isobaric?
regards Andrew T. |
#4 | |||
b 1(1) |
#5 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| what happens with more drivers inside isobaric? | neutron7 | Subwoofers | 7 | 10th February 2007 08:52 PM |
| Isobaric with dissimilar drivers. | Circlotron | Multi-Way | 10 | 6th February 2007 09:09 AM |
| Isobaric with odd number of drivers? | needtubes | Subwoofers | 9 | 11th June 2006 06:42 PM |
| Isobaric horn + Hornresp | Mr Evil | Multi-Way | 7 | 30th November 2004 09:33 PM |
| Page generated in 0.08039 seconds (71.38% PHP - 28.62% MySQL) with 11 queries |
