Hey Guys,
Newbie here, I want to build a box similar to this: http://pro-audio.musiciansfriend.com...fer?sku=601207 I have already purchased all the hardware necessary and the woofers. I have some car audio box building experience. The problem is I only know how to make sealed boxes. I never learned vented or ported. I have all the specs for the woofer. Now I just need direction on planning for the box. Any help would be greatly appreciated. Oh I am building two and using a QSC RMX 1850HD amplifier running at 4 ohms stereo. Chuck Peavey 1808-4 BWX 18" Impedance: 4 Ohms Power capacity: 2000 W Peak 1000 W Program 500 W Continuous Sensitivity: 97.5 dB / 1 W 1 m Usable freq. range: 35 Hz ~ 1 kHz Cone: Kevlar® impregnated cellulose Voice coil diameter: 4.0" / 100 mm Voice coil material: Aluminum ribbon wire Polyimide-impregnated fiberglass former Nomex® stiffener Solderless diffusion welded OFHC copper leads Net weight lb. / kg: 18 lbs. / 8.2 kg Znom (ohms) 4 Revc (ohms) 3.47 Sd (Square Meters) 0.1237 BL (T/M) 13.94 Fo (Hz) 38.9 Vas (liters) 311.7 Cms (uM/N) 143.4 Mms (gm) 116.6 Qms 10.215 Qes 0.509 Qts 0.485 Xmax (mm) 2.0 Le (mH) 0.16 SPL (1W 1m) 97.5 No (%) 3.50% Vd (cu. in. / ml) 29.5 / 483 Pmax (Watts pgm.) 1000 Disp (cu. in. / ml) 228 / 3737 |
#2 |
Greets!
OK, then build a 'sealed' box that's ~222.64 L net (i.e. after factoring in the volume loss due to the driver, vent and any bracing) and vent it with a 20.32 cm diameter pipe (or some other duct shape of equivalent area) by 20.32 cm long to get a ~Fs tuning with a ~30 Hz F10 sitting on a solid, non 'floating' floor. Line one side, top and back panel with ~2.54 cm acoustic fiberglass insulation or similar to smooth out its vent induced HF 'hash' (resonances) above ~500 Hz. BTW, for my records, are these published or measured specs? GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Specs:
#4 |
Yes those are published specs. Thank you for the input. I cannot wait to see how it turns out. Will post pix when finished.
#5 |
You're welcome! Looking forward to your thoughts on its performance.
GM
#6 |
Xmax (mm) 2.0
You didn't buy low riders.... Those peavey's (1804-4 black widow's) aren't made for big sub use. You'll exceed xmax at less than 50 watts of power in the proposed vented cabinet. Can you exchange those for the low riders? |
#7 |
True, but at ~115 dB/m, ~120 dB/m on a 100 W minimal overdrive and +6 dB for a pair, just how much is required for a mobile DJ app?
GM
#8 |
Depends on the DJ/room size and other parameters but ussually a lot and preferably even more than that.
Even 4,0 mm would be considered little. Hopefully Xmech is considerably larger. Best regards Johan
Impossibilities we do immediatly, miracles take slightly longer. |
#9 |
Sheesh! That's too loud for banquet, etc. rooms, school auditoriums, etc.. Back when I helped with such apps, the SPL was based on the drum kit regardless of room size, so 115-120 dB was plenty for the <100 Hz BW. Big outdoor events requires more of course, but these aren't 'mobile DJ' events.
And to think I use to take a lot of verbal abuse for waste of money/space 'overkill' designs that I did to keep distortion low and now it seems they would be drowned out with SPLs high enough to permanently damage/distort the ears. Oh well, I know how to do 'loud' for a given driver and the BMX in a band-pass should peak on the far side of 130 dB in the ~50-100 Hz BW even with some thermal power compression. GM
#10 | |
| mobile monitors | zaboo3 | Everything Else | 1 | 17th July 2003 12:05 PM |
| Page generated in 0.10883 seconds (76.75% PHP - 23.25% MySQL) with 11 queries |
