Old 13th July 2009, 08:29 PM   #121
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
next pic
PASSIONN
Old 13th July 2009, 08:31 PM   #122
brsanko's Avatar
third pic
PASSIONN
Old 14th July 2009, 12:13 AM   #123
mwmkravchenko's Avatar
Default Hi Guys
Zobsky
The power input is 70 watts in the pic posted.
brsanko
I like a bit of competition. It's why we post things right?
Here is my input screen:
What is different is I did my simulation in a wall floor environment.
I accounted for the actual 4 ohm load and lowered the input voltage to adjust for that to 2.00 volts.
If I do the same simulation in a car environment I get this:
Are you still happy?
Mark
Mark
Old 14th July 2009, 12:46 AM   #124
brsanko's Avatar
Well mine is a whole lot smaller. Why on earth do you have the ang set to 2.0 pi are you planning on putting it in the middle of a large room?
PASSIONN
Old 14th July 2009, 12:51 AM   #125
brsanko's Avatar
Oh I see you have 2 drivers in yours. When you can hit 125db with one is 2 really necessary. I mean you can only blow your eardrums once.
PASSIONN
Old 14th July 2009, 01:04 AM   #126
Default Maybe I will check out your design a little more carefully!
You pulled this off with one driver!
This I have to check out more carefully.
Mark
Mark
Old 14th July 2009, 06:36 AM   #127
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I told you, your designs were not yet mature... But I was too busy to demonstrate it (I'm finishing a class D sub amplifier for the pro audio market capable of several kw at 4 and 2 ohms, extremely time consuming).
I use to feel like the small child in The Emperor's New Clothes tale
Old 15th July 2009, 03:26 AM   #128
Default One BRain plus my Half a brain = one brain?
Hello BRSANKO
I did play with your work. I fooled around a bit. Added a driver tweeked the works and added a couple of litres. Now we are good down to 18hz!
This is probably what is going to get built unless you or we can better it.
So 116 liters and another driver drops us an octave and gets us a couple of extra db. I whole heartedly agree that this is not needed for a car but this box could also work in a house.
The TRIO8 has a linear X-max of 14mm and a mechanical of 19mm so I don't think that it would be dieing at these levels.
Mark
Mark
Old 15th July 2009, 03:35 AM   #129
Calling JLH come in JLH
I compaed this design to the one you posted a while back with the two Tang Band 8" drivers. They are less efficient and actually have a smaller Sd. But the box models well. Did you ever do a one watt SPL measurement on the box?
This one seems close and is almost half the size.
Mark
Mark
Old 15th July 2009, 03:38 AM   #130
Default I forgot to post box size
The rough box size is:
Imperial 9.5 x 38 x 24
Metric 22.86 x 96.52 x 54.38
Of course this can be jugled a bit but the rough calculation was done with 120 litres. So there will be a bit more loss in horn path materials. But still 4.23 cubic feet will get you to levels few have heard. And the outlay in cash and amplifier power is modest.
Mark
Mark
Lab12 - Tapped Horn - layertone Subwoofers 136 27th November 2011 04:19 AM
Evolution of the Tapped Horn Don Snyder Subwoofers 30 18th August 2010 02:06 PM
Tapped Horn for Midrange Patrick Bateman Full Range 2 30th October 2006 03:09 PM
Page generated in 0.10589 seconds (78.14% PHP - 21.86% MySQL) with 11 queries
