Hi guys, i dont have money to purchase an subwoofer, but i have an Polk MM2124 Sub that i removed from my Car, is possible to use it for my HT?
http://www.polkaudio.com/caraudio/specs/recent/mm2124/ i want to know what kind of box and amp recommend me for this monster |
#2 |
I have had good luck with several "car" subs for home theater.
As far as that particular one, Polk says it works well in sealed or ported enclosures, it also models pretty well in a tapped horn. Without the actual thiele-small specs - stick with the simpler enclosures - sealed or ported. A typical plate amp should work fine - it is a 4 ohm driver. Not sure what you'll be able to find locally, but Parts Express has a lot of choices. 500 watts will be more than enough. |
#3 |
i used it in my car in sealed, Everyone recommended me Sealed, looks like this time will go sealed too.
#4 |
i have the Car AMP too, what do you think to connect it with some kind of transformer to get 14V ? will be enough? or think that is better to pruchase an 500W Plate Amp?
http://www.polkaudio.com/caraudio/su...ments=standard I was using this box in the Car, will be the same for my HT? i will get nice result too? |
#5 |
Normally, for HT you want useful performance down to at least 20 Hz in-room. For an apartment or similar where neighbors share at least one side of your home and/or the room is very small, then it needs to roll off fairly high, so the little sealed box may be OK for these situations. Otherwise, based on this driver's published specs it needs to be either a corner loaded sealed or some form of TL alignment in the 150-200 L range or 300+ L for a TH.
It's been awhile, but last time I checked it was cheaper to buy a high power prosound amp (especially used) than a suitable AC/DC power converter or sealed/no maintenance battery + charger to drive your existing amp, but check around to make sure this is still the case. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| Refurbishing Polk RTA 12 | 901Fixer | Multi-Way | 1 | 14th July 2009 03:24 PM |
| Polk SDA-1b's | jagster | Multi-Way | 1 | 12th May 2008 07:50 PM |
| ls70 polk | tadiam | Multi-Way | 0 | 16th December 2007 07:19 PM |
| Polk Sub ??????? | ralph-bway | Subwoofers | 1 | 20th October 2005 12:39 AM |
| Polk RT3 help | godam | Multi-Way | 0 | 31st March 2003 09:51 AM |
| Page generated in 0.07852 seconds (75.95% PHP - 24.05% MySQL) with 10 queries |
