Old 8th June 2009, 02:10 PM   #1
elindse is offline elindse  Norway
Default Using Monacor IMG Stageline SP385-G as subwoofers for movies?
All,
Background:
Some years back I purchased 2 Monacor IMG Stageline SP385-G for use in a medium concert arena.
Up until now these has not been in use, and I am looking at the possiblity to use them as a additional subwoofer in the load speaker system for movie.
Use: Mostly movies, but also some music.
Size: Not extremely big, and the finisih must be good looking.
Today
1,) Are the woofers suitable for their new task?
2,) Any tricks regarding setup? Standard, push-pull, or even using only one of them?
3,) Volume of the box?
4,) Damping required? Minmal, typical or massive?
5,) Anyone has a wiring diagram for a suitable pass for above questions?
Best regards
Erik
Old 10th June 2009, 09:33 AM   #2
kepa1 is offline kepa1  France
Hey,
This driver is made for amplified instruments (meaning mid-bass range) and will perform well on an open baffle, so I guess it will not produce the bass extension you are after.
Old 10th June 2009, 12:00 PM   #3
Piek is offline Piek  Europe
Piek's Avatar
I hope you want to use a dedicated Amplifier for it?
TSP-wise: with a single driver smallest (closed) box will be around 170l(heavily damped with rockwool)-250l for fb around 47Hz. You could half that when doing it isobaric, resulting in just one subwoofer.
Bassreflex will be very large...
Try simulating a Bandpass with WinISD is my suggestion for depth and volume. Ripol is also maybe 'ok' as a filler if other subs are present, but it wont be very loud. I had similar drivers in a Ripol it wasnt sufficient for home cinema.
-Micha
movies that are special vasyachkin The Lounge 0 20th January 2008 10:37 AM
Naim stageline K exurbia Analogue Source 2 8th August 2007 10:20 AM
Mcx-2100 Img Stageline titoon Parts 0 25th August 2006 11:01 PM
Top 10 Ozzie movies ever Stanislav Everything Else 30 25th October 2003 10:54 PM
Recording Movies Onto CD kelticwizard Everything Else 2 18th June 2003 07:13 PM
Page generated in 0.07545 seconds (71.41% PHP - 28.59% MySQL) with 10 queries
