Old 8th June 2009, 09:25 AM   #1
Default Which (small?) bass horn for Coral 12-inchers?
I need advice on best (small) bass horn cabinets for these drivers I have spare. They're in good nick. I was thinking of knocking up a 3-way using the matching Coral 5-inchers and dual tweeters....but one of the mids is a bit suss....so I'm leaning towards some horn subs as another fun DIY project.
Paper cone 12" bass driver, about 94 dB sensitivity, lineair upto 3kHz, Re=6.6 Ohm, Fs=44 Hz, Qms=11.8, Qes=0.62, Qts=0.6, Mms=40 g, Cms=0.33 mm/N, Vas=110 L, BxL= 10.8 N/A, L1k=2.6 mH, 60W, 8 Ohm, Japan.
http://www.machmat.com/sales/images2/coral12l25b.jpg
I was thinking about a small folded horn...and am aiming for 45Hz to aroun 150Hz.
Ideas?
Thanks.
Old 9th June 2009, 07:22 PM   #2
GM is offline GM  United States
GM's Avatar
With this driver's specs, 'small', 'bass', 'horn' are all mutually exclusive. Even a max flat vented alignment is around 408 L, so shrinking it will make it under-damped, requiring stuffing the vent to make it ~aperiodic.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th June 2009, 09:58 PM   #3
Thanks GM
William Cowan has nice 'small' horn...and uses x2 10-inch units.
http://www.cowanaudio.com/ (Go to Horn Sub Jr)
Was thinking along these lines with the single 12-inch.
This is just a fun/trial project.....for home use only.
Andrew
Old 10th June 2009, 01:23 AM   #4
GM's Avatar
You're welcome!
OK, add a driver, truncate the horn, but do it with just one driver and its lower corner frequency rises, i.e. no bass unless corner loaded, so with that in mind..........
GM
File Type: gif coral 12' 44-142 hz corner loaded flh - specs.gif (15.4 KB, 134 views)
Old 10th June 2009, 06:35 AM   #5
Piek is offline Piek  Europe
Piek's Avatar
Is this driver out of the Coral BX series speakers?
Micha
Old 10th June 2009, 08:02 AM   #6
Micha
Not sure.
I picked up the drivers along with Coral 5-inchers, plus dual tweeters. One of the mids is a little bit suss...hence me playing around with the bass units only.
FS: Coral alnico 6 inchers and Coral H-12c alnico tweeters MichaelPublic Swap Meet 2 27th June 2008 11:24 PM
what's best enclosure design for Coral Beta 8 Speaker ? which horn ? Schematic ? calico88 Full Range 31 30th November 2006 07:38 AM
3d spiral horn for coral driver! ycliew Full Range 0 31st May 2006 04:50 PM
Small bass Horn? bhg41088 Multi-Way 23 3rd May 2004 10:59 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
Page generated in 0.07298 seconds (82.35% PHP - 17.65% MySQL) with 11 queries
