TH mouth area
TH mouth area
Old 7th June 2009, 03:03 PM   #1
bubblersound is offline bubblersound  United States
Default TH mouth area
Lets say size doesn't matter. What happens if the mouth area of a well designed tapped horn was increased? Would it gain output or be more efficient as conventional horns do?
Old 7th June 2009, 03:28 PM   #2
R.I.P.
run Hornresp and see for your self.
or add a horn mouth to the exit of a TH.
regards Andrew T.
Old 7th June 2009, 05:57 PM   #3
MaVo is offline MaVo  Germany
as you approximate the mouth size of a normal horn, the systems behaviour gets more like a normal horn. same mouth size, same performance. if you have room for BIG, then stick with a front loaded horn, as they are easier to design.
TH mouth areaHide this!Advertise here!
Talking out of both sides of its mouth brucegseidner Full Range 6 6th August 2009 08:02 AM
horn cut off frequency, dependant on mouth area or circumference? Puggie Full Range 7 26th July 2006 12:08 PM
Horn Mouth Diffraction mefistofelez Multi-Way 11 14th October 2005 01:04 AM
rear horn mouth area big_kahunah Full Range 1 16th August 2005 01:35 AM
Screen in horn mouth? Stocker Multi-Way 7 9th March 2005 09:39 AM
