Seeking some ideas:
We are currently digging up the entire basement floor of our Bed and Breakfast in order to put in a 2700 sq ft Pub. We will end up with 9' ceilings. heated slab floors, etc.
The pub will have areas for pool tables, a bar, two fireplaces, etc. I want good quality sound in the largest room.
I'd really like to do something fun with subs....like bury some large diameter PVC pipes, etc. While we have the floor ripped up, it would be easy to put them in.
I found some 12" and 14" tubes, but the local place that sells this stuff charges something like $150 each for large elbows, and about $120 for a cap.
I'm thinking sealed design, and would prefer something like a good 12" or 15" woofer. Does anyone have any good ideas?
Thanks!
Thanks!
You might want to check with pipe supply yards that sell septic system items. There are some spiral ribbed pipes that are very ridgid and go up to 48" in diameter. Of course, they get very expensive per foot. However, you could bury them and not worry about flexing! If you do put these in the ground, you will have problems with condensation. One way to avoid that issue is to encase the tube with about 4" of sprayed on urethane foam. All this will cost you more than building a box, but you would get that subterranean rumble! There are no shortcuts to this to do it right.
spiral ribbed pipe sub
Thank you for the suggestion. I have never seen that pipe..never really looked at a septic system.
I do have my own Graco foam machine, so the urethane foam is almost a given for me.
I also thought about those concrete culvert sections that are widely available, but don't know if concrete is as "Dead" as you would think it is. I suppose that with foam around it, dirt, and then concrete, it really would not matter anyway.
A friend suggested just taking two sonotubes, say one 24" and one 18", and pour in between them. You would just leave the form in place, and foam around it. Since we are going to pour the floor anyway, that would be the cheapest option.
Thanks for the idea.
Just make sure you seal the separations totally with the foam, sonotube forms will soak up moisture over time (even the waxed ones, and mildew. Seal the cut ends. And, you will need to add some kind of acoustic dampener (acousta-stuff, fiberglass, etc., to kill the standing waves. But if you have a foam machine, anything is possible. I presume you are using closed cell urethane. You could use a heater register over the top. Would that ever give people a thrill!
What ever you do may I suggest that you remember to make easy access to replace the driver when ( or if ) it blows.
Howabout a fake fireplace in a corner with the woofer(s) hidden in the brickwork, still utilize the underground box volume with a simple right angle concrete sewer connection for the change of direction.
Use 4 * 12inch car subs wired series /parallel or 2 * 15 in series and a cheap amp bridged.
+1 on sealed design
+1 on the heat register cover
+1 on the future access capability
Here's what I might do:
1) Research potential driver candidates
2) Dig a square hole
3) Line hole (sides and bottom) with blue styrofoam (1 1/2" most likely)
4) Line styrofoam with visqueen (overlapping and taping to ensure good seal)
5) Find a plastic garbage can with internal volume appropriate for driver
6) Put grabage can in hole and fill around outside with concrete, remove garbage can after concrete hardens
7) Build 1 1/2" baffle (2 x 3/4 plywood glued)
Then you have a fairly cheap, watertight chamber which will remain pretty close to the same temperature as the room and avoiding problems related to condensation and heat/cool expansion cycles
IMHO there is no need for foam or damping...but it would not hurt anything.
Of course you would have to do some precise measuring and possibly silicone or some type of efforts to seal the baffle to the concrete chamber.
You could bring wire in through 1/2" Schedule 40 or similar and seal space around wires with that expanding foam stuff (can't think of it's name)
my .02c
I'm jealous, sounds like you are gonna have a really great room there
my .02c
P.S.
The baffle board would need more than just an airtight seal as mentioned above.
It would also need to be securely physically bound to the concrete "cabinet". If not the baffle would just vibrate, bass would not be solid and the airtight seal would not last long.
What are those things called that are embedded in concrete, are threaded on one end, and used to bolt sill plate to slabs? Several of those with huge washers would be one possible way.
P.P.S.
Having thought more, I believe that vented design would be better than sealed. Having a vent would ensure that the temperature and humidity inside the speaker chamber would be the same as that in the room.
With a sealed design any discrepancy in humidity between the room and the speaker chamber would tend to migrate through the sub-woofer...not a good thing for longevity.
Other random thoughts:
Use at least a 15" sub-woofer. 2700 sq ft is a good sized room. Even though, I assume, that the sound system may not be inteded to fully cover the entire area, a 12" in a cubic area that that large may not do enough. An 18" or dual 15's....may be good to consider.
May be good to use sub-woofers with poly cones and rubber surrounds. One reason is to further minimize and potential damage from moisture problems. Another reason....beer spills.
in floor sub ideas
Guys:
These are all great ideas. The last one, the tube in the floor is the closest to the concept I was originaly thinking. It is really inconspicuous.
I also like the idea of forming with a trash can....it has the advantage of tapered sides. Maybe I'm making a mistake with this, but I'm not too worried about moisture. One, we have not have moisture in the basement, and that is before I do my improvements, including full perimeter drains, etc. Also, all my floors are heated slabs. That has the advantage of dying things out. At least while the boiler is on.....
The foam I use is closed cell. It is impervious to water. They make it right here in town, up to 3# density, which is so hard you can walk on it for roofing. What ever you stick together with it stays stuck, period. I have long wondered what would be the effect of filling between 2 sonotubes with foam, rather than concrete.
As to drivers, no ideas yet. I was assuming 15" though.
The other person suggested fake fireplace in the corner...interesting, we have two chimneys down there, one of which will have a fireplace added. It has large voids to either side, which could be bricked in to create a shelf about 30"H, 40" wide, and up to 24" deep. If done in brick to match the chimneys, you could hide a driver in there, and it could extend into the ground as far as you chose.
It is a big area, but the speakers will be on one end of the "U" shaped space.
Thanks for the ideas!
Guys:
When I built my son his 18th birthaday present I wanted to utilize the old chimney and fireplace as a sub box, unfortunately his mother objected and it was never done, but I did plan it. Those old chimneys have a huge volume and the idea has been in the back of my mind ever since
Homebuilder, you are on the right track with the 3 lb density foam. I've used thousands of cubic feet of it for all kinds of projects. Even though you may have a heated floor and perimiter drains, more than likely your hole will be deeper than that and the core of the earth will be colder than your room. I doubt you have enough BTU's to warm the planet. But if you insulate it to the top, you will be ok. When the temperature gets low enough for dew point, you will have moisture, and an absolute seal is required to the slab above. It is not so bad since you will be on an inside wall, and the earth will be 45 degrees or so, but near the outside wall it can be problematic. I dealt with this in Colorado with outside stone walls at 35 below zero, and it took a 4" layer of 3 lb foam to stop the condensation. Great stuff to use!
sub
Chipperman:
Point well taken. Along the lines of some of the suggestions, I thought of having it stick part way out of the slab, but disguising that part in some fashion. Maybe with bricks and mortar.
That foam is great stuff, eh?
Have you tried using any of it in a speaker, such as in between two layers of something else? ie Sonotube. It is very rigid, and should not resonate.
Thanks!
Chipperman:
Thanks!
..As to drivers, no ideas yet. I was assuming 15" though. .
Hi homebuilder,
FYI,Here's a suggestion using 15” Dayton TIT400C-4 instead of the 12” Dayton RSS315HF-4.
b
1(1)
- Subwoofers
- Suggestions for hidden sub
