Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 4th June 2009, 08:16 AM   #1
Default Dampening in Tapped Horns??
I'm interested in knowin if people use dampening in tapped horns? Any ideas appreciated.
I'm building the large 2.2meter horn.
Andrew.
Old 4th June 2009, 08:35 AM   #2
I've got a stripe (15*200 cm) from a polyester sheet hanging
loose in the second part (half -> mouth) of my tapped horns,
single fold, 400 cm. It made the bass tighter and more defined
than without damping.
Old 4th June 2009, 11:23 AM   #3
Thanks Petter
What do you mean, polyester?
Old 4th June 2009, 01:28 PM   #4
Go to:
Dual 8" tapped horn = TH-SPUD
Polyester fiberfil is a spun plastic material commonly sold in sheets or bulk. Used as insulation or sound control,
it works like fiberglas, but without the irritation.
The main problem with dampening, is how much do you need, and where do you need it. This is often a cut-and-try
process, and doesn't model well.
Don
Old 4th June 2009, 09:33 PM   #5
Thanks Don...that's a good link.
I'll give the horn about 1/3 stuffing based on what I've read.
For my TH (the long 2.2m version), I'll have one entire side with a removable pane. Probably use that awful black head-gasket for a sealing agent....but may not even need that for he initial evaluation stages. Thoughts? Perhaps a simple dry cork or foam might be better...less messy.
Old 5th June 2009, 12:22 AM   #6
Dilletante, tinkerer and beggathoner supreme
Moondog55's Avatar
Better stuff at Clarke Rubber,
buy a few meters of the soft round- section foam they sell as filler for brick-work and sealing around door jambs, it is cheap and reusable and available in sections from 3mm to 45mm.
i can't think of the term for it at the moment, blame the brain cloud
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 5th June 2009, 01:25 AM   #7
Just vsited Clarke & Rubber...but bough the polyfill from Spotlight. I'll try that first.
Cheers.
Old 5th June 2009, 08:11 AM   #8
Just spent 8 hours building the horn. It's up and running.
Talk about OVER KILL. The thing can't get past 1/10 volume on the (600-watt) amp.
Heaps of room mods to attend to due to vibration etc. This unit is better suited to a small theatre rather than a lounge room. (Wife just got home from work to see what's happened to the lounge.....not impressed. My Lowther Big Fun Horns now look.....puny!)
I tried Madonna - Dick Tracy soundtrack...with the plate amp on only...and no stereo amp....a good way to test the sub.
The house just shook....hardly pleasant....but very effective.
I'm learning about the importance of integrating bass with mids/highs....it's hard work!
I think I should build the 30Hz smaller horn...half the size.
Old 5th June 2009, 08:38 AM   #9
Moondog55's Avatar
When you say 2.2meter do you mean 1/4 wavelength 2.2M or that the units are 2.2M tall, I'm still trying to get my head around tapped horns.
I have a pair of Cerwin Vega 124's that would probably work; but I'm not that willing to experiment just at the moment.
Also I don't ATM have a couple of 1000Watt amps
Old 8th June 2009, 07:21 AM   #10
2.2m tall...horn path is twice that....
Thread Tools
jbell's set of four tapped horns davygrvy Subwoofers 126 24th February 2010 05:59 PM
how to model tapped horns? weikertball Subwoofers 2 11th January 2009 09:43 PM
tapped horns - a different perspective & an alternative vasyachkin Multi-Way 54 14th February 2008 04:25 AM
Effect of using dampening in rear horns? Geek Multi-Way 19 26th September 2004 01:11 PM
Page generated in 0.09049702 seconds (78.98% PHP - 21.02% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
