Old 28th May 2009, 03:45 AM   #1
Default Looking for an amp to pair with this driver..
I'm planning a subwoofer building that will use a single CSS SDX15 driver. Specifications can be seen here:http://www.creativesound.ca/details.php?model=SDX15
The enclosure is going to be ~6.75cu.ft. and tuned to ~20Hz with two 4" flared ports. I'm looking a subwoofer plate amp that outputs about 1,000w @ 4 ohm, as this is the RMS rating on the driver. I would prefer an amp with features such as adjustable low-pass 'rumble' filter and RCA/LFE inputs. I'm looking at a budget of about $500 CAD for this amplifier.
I have been looking at the Dayton HSPA1000 which is sold on the Creative Sound website for $450, although I've heard mixed reviews about it. Some people have complained of it lacking power at high volumes, and this is a bit of an issue for me.
Any suggestion would be appreciated!
Old 28th May 2009, 10:24 PM   #2
Speakerholic
Cal Weldon's Avatar
That combo should be fine. Plate amps are not the greatest but if you are getting a clean 250 watts from it you're doing ok. If you feel the need to step up, there are things like this from Reckhorn where you would use a regular amp in bridge mode.
http://www.creativesound.ca/details.php?model=B-1
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 29th May 2009, 02:23 AM   #3
zora is offline zora  United States
If you want to stick with a plate amp, I would look at the Keiga 52100 or the Elemental Designs LT1300 (keiga-based). These both have the features you want, and unlike the PE amp will make their rated power (plus a little more.)
JP
Old 29th May 2009, 04:02 AM   #4
Thanks for the suggestions. I was also looking at the eD LT1300, although it's a bit outside of my price range.
I'm just curious, why is it that you aren't fond of plate amps?
Old 29th May 2009, 02:27 PM   #5
I have, and have used, both high-power plate amps and pro amps. They each have their own positive aspects. I can say that the Keiga-powered AV15/PR subs I have would be more than enough for 99% of the people interested in HT or music subwoofers.
JP
Tweeter to Pair with 4" Mid-Bass Driver ? bordins Multi-Way 2 4th April 2008 10:32 AM
Last Pair of Pete Millett Universal Driver PCB's Geek Swap Meet 2 25th March 2008 09:03 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
FS: RadioShack 40-1354A driver pair theAnonymous1 Swap Meet 0 25th April 2006 10:39 PM
WTB - JBL 2404H, or 2405H UHF driver pair jlharden Swap Meet 0 3rd February 2005 09:01 PM
Page generated in 0.06831 seconds (83.34% PHP - 16.66% MySQL) with 10 queries
