Horn response Pardon my ignorance
Old 26th May 2009, 01:11 AM   #1
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Default Horn response Pardon my ignorance
First off thank-you to David Bean for the program and all the hard work you have done with it.
Having downloaded the program and read through the notes I am still at a loss as how to enter driver parameters when all I have are the basic T/S date supplied my the manufacturer.
It is a stupid question I know but I seem to be having some old timers trouble ATM.
I was just wondering if I could squeeze my CV 124s into a tapped horn and get the extra SPL without losing the deep extension they have in a TL
Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 26th May 2009, 06:45 AM   #2
David McBean is offline David McBean  Australia
Default Re: Horn response Pardon my ignorance
Originally posted by Moondog55
Having downloaded the program and read through the notes I am still at a loss as how to enter driver parameters when all I have are the basic T/S data supplied by the manufacturer.
Hi Ted,
You can use the 'Calculate Parameter' tool when a record is in Edit mode to derive Cms, Mmd, Bl and Rms values (in that order) from the relevant Thiele-Small parameters. See page 8 of the Hornresp Help file for details.
Kind regards,
David
www.hornresp.net
Old 26th May 2009, 07:19 AM   #3
Moondog55's Avatar
OK, I think I have that part of it now??
Thanx David, it is going to take a while for me to get a handle on it.
I didn't think tapped horns were going to be as simple as a sealed box.
Ted
Old 26th May 2009, 10:33 AM   #4
Moondog55's Avatar
What happens if you run the taper in a tapped horn the other way, that is in a contracting taper not an expanding one??
Can I model that in Horn Response??
Old 26th May 2009, 11:31 AM   #5
Volenti is offline Volenti  Australia
Indeed you can, you can also model TL's, vented and bandpass enclosures as well, it's very flexable.
Many tapped horns tend to have the driver at the very start and end of the line, and they model in a very similar fashion to expanding TL's, so if you reverse the taper, you end up with a more or less typical tapered TL.
Old 31st May 2009, 09:48 AM   #6
Moondog55's Avatar
Thanx Volenti.
Must say that I am still having trouble tho.
When designing a tapped horn ; how much lower than driver Fs should the horn length be?? fixed percentage of nominal figure??
if driver resonant frequency is 23 Hz, is an 18 Hz length appropriate and how much flare does a driver with a very low Vas need, or is horn volume flexible??
In other words where do you start the design point?/
I have read ALL of the threads on tapped horns and I'm just as confused now as I was 3 months ago.
The drivers I have are totally wasted in their little sealed boxes
Horn response Pardon my ignoranceHide this!Advertise here!
junkiest PC that'll run horn response? pjanda1 Full Range 9 13th July 2009 10:00 AM
More then one driver in Horn Response jamikl Subwoofers 2 5th February 2009 12:44 AM
Pardon my ignorance da77enj Subwoofers 4 14th October 2007 07:15 PM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 11:44 PM
Comments on bass horn sim in horn response paulspencer Subwoofers 38 1st November 2005 09:34 PM
Copyright ©1999-2017 diyAudio
