Help with Subwoofer amp Low-Pass Filtering
I'm designing a BTL subwoofer amp as part of a system.
To make it simple, I want to have the frequency cutoff fixed, around approx 100-150hz or so. It doesn't have to be perfect, just as long as voices aren't coming from the subwoofer too much.
I did some research and calculated some values, but I haven't built the circuit yet. It's an opamp preamp/filter, but also the subwoofer amplifier itself is also used as an additional filtering stage, and as a plus, should add stability.
Here's the circuit.
Will this work, and if not, what would need to be changed?
