#21 | |
#22 |
So you are saying there is no loss at high volumes from the extra surface area inside multiple smaller ports?
Candidates for the Darwin Award should not read this author. |
#23 | |
Yes, there is more loss, more damping, with multiple ports. But I even add foam in my ports to dampen them, because I want some damping in bandpass designs. But SPL loss from turbulence is a quadratic thing and isn't a factor until the velocities get quite high. SO I design the ports to keep them in the low loss (turbulence), but well damped region of operation. |
#24 |
Thank you.
#25 | |
Account Disabled
I wrote before: due to the square in Fr^2 ~ Aeff/Leff small errors in port length or area won't do to much. A deviation of 10% in Leff or Aeff will only cause Fr changeing about 5%. That is neglegible compared to atmospheric influences as air pressure, humidity etc. and The above correction to Mr. Geddes' note was done in case of someone building a double port of lets say 1" length + 10" length. The effective length will be much smaller than the average of both! It will be more around 1.1" instead of 5.5". It's not as easy as Mr Geddes advises You. If the difference of length is small, I told You You could take the average. Small deviations to the correct measures don't harm at all. To be right if the lengths differ much please take the "x-perts" formulas. Thats all folks! The Q-thing: take a port of 10 x 10 dimension or take 4 ports of 5 x 10. Experience the difference! |
#26 |
one thing that may work, lets say the driver is in a box and the port in this case is simply a shelf at the bottom of the speaker.if you added a second driver and attatched a piece of wood to it on a slider to block and unblock the port. then theorietically the port would change its tuning frequency dependent on the note being played. what i am basicly saying is if you had a port that could somehow alter its tuning to match the frequecy being played, it may well enable the a tuning drom 100hz-20hz be funny to watch a port changing shape when different bass notes hit. im not sure how it woyld work in reality, but in imagination it is possable or lets say a slider mechenisom where you have a load of ports like organ pipes, and when different notes hit, then via a computer or summin, the port that matches the frequency opens up. not explaining to well, but its food for thought |
#27 | |
Now if all you want is loud "burps" at a specific frequency, tuning within the functional range is used. |
#28 |
Proud Union Member
Just to add some real world experience. Both the Meyer 600HP and 700HP use two pairs of differently sized ports.
I'm sure there are others out there, but those are too I'm very familiar with. |
#29 | |
Even when a sub is band passed well below the port resonance, upper harmonics generated by the speakers when run hard can still be amplified by the port resonance. In other words, the "optimally tuned large very low turbulence port" honks Art |
| Port length - multiple ports | mashaffer | Multi-Way | 9 | 14th July 2006 09:15 AM |
| Are multiple ports better ? | goldyrathore | Subwoofers | 38 | 7th July 2005 10:21 AM |
| Multiple ports Tempest | Stew320 | Subwoofers | 9 | 8th July 2004 04:10 PM |
| curved ports vs. multiple ports | Craig | Multi-Way | 1 | 22nd September 2002 07:30 AM |
| Page generated in 0.11984 seconds (80.73% PHP - 19.27% MySQL) with 11 queries |
