Old 15th May 2009, 06:30 PM   #1
ryan750 is offline ryan750  Philippines
Default too large box
hi, is it possible to decrease the volume of a box??? hmm. dumping some stuff inside?? or something like that. tnx,
Old 15th May 2009, 06:55 PM   #2
Thawach is offline Thawach  Thailand
Thawach's Avatar
yes u can decrease the volume of a box and put some stuff inside.
Old 15th May 2009, 07:34 PM   #3
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
You have got it backwards...stufing a sealed enclosure with dacron or fibreglass will INCREASE the apperant size of the box.
The system will be increased 15% for Dacron, 18% for fibreglass.
Remember what happens when you compress air??It increases in temperature..adding stuffing adds a thermal mass that the air is trying to heat up...sinking the heat...making for an Isothermal process, rather than an Adiabatic process.
Myself I use Cotton batting..which I believe is superior, but can easily mold if moisture is present.
_________________________________________Rick.....
Old 15th May 2009, 08:06 PM   #4
Speakerholic
Cal Weldon's Avatar
I think he meant to put some stuff inside, not stuffing as you rightly pointed out.
Yes, put something like pieces of wood or bricks to decrease the volume.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 15th May 2009, 08:14 PM   #5
tinitus is offline tinitus  Europe
Or line the inside with foam with closed cells, thats not acoustic transparent
Or like Cal says, use wood
Maybe a good idea to mount pieces of wooden sticks in all inside joints, with some kind of flexible glue
Bags with dry sand has also been used
Old 15th May 2009, 08:38 PM   #6
Thawach's Avatar
i ever did by bracing the box a lot.
Old 15th May 2009, 09:45 PM   #7
My bad...I see now. Bag-O-sand..seems most simple, can take up a lot of volume. The added weight shouldn't be too bad, might reinforce the structure somewhat.
_______________________________________________Ric k...
Old 15th May 2009, 10:07 PM   #8
Speakerholic
Cal Weldon's Avatar
I wonder if a bag of sand is dense enough or if it might act a bit like the fiber type stuffing?
I have always used old pieces of lumber when starting with oversized test boxes.
Old 16th May 2009, 01:19 PM   #9
chris661's Avatar
The best I found was empty bottles, filled with water. This was you can choose the amount you reduce it by, to the nearest 1/2 litre.
Better start drinking that Coke....
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 16th May 2009, 05:28 PM   #10
gni is offline gni  United States
gni's Avatar
Why not sand in the liter bottles? The bottles is quite creative.
I glue blocks of wood. . . precise also. . . particle board is cheap and glues well.
FS: Large inductors, Large Ports, and Leaky Holes luvdunhill Swap Meet 10 6th March 2009 03:01 PM
Large Cone/large VC or several medium sized cones / medium VCs vajolet Multi-Way 14 3rd December 2007 06:10 PM
WTB: Large Cap's Transmitter Man Swap Meet 0 7th August 2004 08:23 PM
Large Cap! What to do? Christian Solid State 8 23rd September 2002 04:40 AM
Page generated in 0.09566 seconds (76.36% PHP - 23.64% MySQL) with 10 queries
